Go Back   Corvette Forum > C4 Corvettes, 1984 - 1996 > C4 ZR-1 Discussion
Register Forgot Password?
Register Search Today's Posts Mark Forums Read FAQ Vendor Directory
Search
C4 ZR-1 Discussion General ZR-1 Corvette Discussion, LT5 Corvette Technical Info, Performance Upgrades, Suspension Setup for Street or Track
Welcome to Corvetteforum.com!
Welcome to Corvetteforum.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Corvetteforum.com today!
Corvette Store
C7 Parts & Accessories
C6 Parts & Accessories
C5 Parts & Accessories
C4 Parts & Accessories
C3 Parts & Accessories
C2 Parts & Accessories
C1 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 06-21-2011, 10:40 PM   #1
1966 BigBlock
CF Member
Default 1990 Zr1 Fuel Injectors
My secondary's started acting up this past weekend on my 8500 mile car. I am going to change primary and secondary's with stock equipment. Anybody have any suggestions on who is the best vendor to purchase from and the required gaskets I am going to need?
1966 BigBlock is offline   Reply With Quote
Old 06-21-2011, 11:24 PM   #2
XLR8TIN
CF Senior Member
XLR8TIN's Avatar
http://jerrysgaskets.com/store2/root/
Go with Accel or RC injectors
XLR8TIN is offline   Reply With Quote
Old 06-22-2011, 12:22 AM   #3
Dominic Sorresso
CF Senior Member
Dominic Sorresso's Avatar
Send a message via AIM to Dominic Sorresso
What does that mean, " my secondaries are acting up" ?
Why does that indicate injectors?
Dominic Sorresso is offline   Reply With Quote
Old 06-22-2011, 12:30 AM   #4
zr-1 guy
CF Senior Member
if you swap them out with stock injectors you're going to be pulling them out sooner rather then later again. swap in after market or ever 93-95 injectors and save yourself lots of time and money
zr-1 guy is offline   Reply With Quote
Old 06-22-2011, 02:56 AM   #5
Paul Workman
CF Senior Member
Paul Workman's Avatar
Quote:
My 90 had NOS (new original stock) exact replacements installed when I bought the car. They lasted 3 years before they too succumbed to the alcohol in the fuel.
I replaced them with the Accel #150821 that I got new from Summit Racing for 16 injectors for about $550 shipped.
Summit might tell you these injectors are not for the LT5. Ignore them, if they do (or don't say what you're application is).
The only thing is you have to do to is remove the little plastic key tab on injectors intended for use in the secondary (or was it the primary?) injector app. (Took me less than a minute ea. when using a Dremel and a grinding spool.)
And, I too echo what Dominic asks regarding the process that lead you to concluding the secondary injectors were at fault? (They may well be bad. Just interested in the process, is all)
P.
Paul Workman is offline   Reply With Quote
Old 06-22-2011, 06:18 AM   #6
96LT4
CF Senior Member
Former Moderator
Cruise-In II Veteran
Cruise-In III Veteran
Cruise-In IV Veteran
Cruise-In V Veteran
Cruise-In VI Veteran
CI3 Car Show Winner
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13
96LT4's Avatar
I put FIC in my 95. So far, so good.
96LT4 is offline   Reply With Quote
Old 06-22-2011, 10:13 AM   #7
mike100
CF Senior Member
mike100's Avatar
I used The Lucas disc type injectors for all 16 positions in my car. The bosch parts probably duplicate the oem spray pattern best, but my car passes CA emissions with ease and idles good at 650, so any of the available injectors for the LT5 should be better than original failed units.
mike100 is offline   Reply With Quote
Old 06-22-2011, 11:08 AM   #8
VetteMed
VetteMed's Avatar
Running FIC here too, no complaints.
VetteMed is offline   Reply With Quote
Old 06-22-2011, 11:21 AM   #9
1966 BigBlock
CF Member
The car runs great at normal power but switch to full power and step on it and it started missing.
Old 06-22-2011, 11:34 AM   #10
Z51JEFF
CF Senior Member
Z51JEFF's Avatar
Location: Fremont Ca. I will do No business with ANY company that boycotts Arizona.
Send a message via AIM to Z51JEFF
Ive also got Accels.These are the same as an L98,just double 16 instead of 8 and also got mine from Summit for the same price.Dont be surprised that the injectors died at 8500 miles,mine died at 8000 miles.
Z51JEFF is offline   Reply With Quote
Old 06-22-2011, 02:28 PM   #11
1966 BigBlock
CF Member
Quote:
And I hear the gas is going to get worse for our cars with more ethanol content.
Old 06-22-2011, 03:00 PM   #12
BlackbirdZ07
CF Senior Member
BlackbirdZ07's Avatar
Send a message via AIM to BlackbirdZ07
FIC... is that Fuel Injector Clinic or Fuel Injector Connection??
Fuel Injector Connection lists several options for LT5's: rebuilt originals modified to accept ethanol, a set that looks like originals, and a cheaper set for $350.
IF you're talking about Fuel Injector Connection, which set are people using?
BlackbirdZ07 is offline   Reply With Quote
Old 06-22-2011, 03:19 PM   #13
VetteMed
VetteMed's Avatar
Fuel Injector Connection. I think most of us are running the rebuilt Bosch $350 set. They have orange tops, and aren't the prettiest injectors in the world, but seem to work well and are ethanol tolerant.
Old 06-22-2011, 03:31 PM   #14
zr-1 guy
CF Senior Member
Quote:
up 5%...thank your local corn growers. not to mention you're now getting 5% worse MPG then before.
Old 06-22-2011, 03:38 PM   #15
1966 BigBlock
CF Member
Yea, I'm in California where this garbage is going for over $4.00 a gallon.
Thank you very much!!
Old 06-22-2011, 09:04 PM   #16
Z51JEFF
CF Senior Member
Z51JEFF's Avatar
Just for the record you cant rebuild a fuel injector,they dont come apart from what Ive read,dont know what exactly constitutes a rebuilt fuel injector.If these are being rebuilt,internal components replaced this might be something new.The ethanol content increase at this point is still up in the air and stations have the option of selling it or not.Nobody knows the extent of possible damage to older car components.Anybody that has even the slightest concerns about this type of thing needs to join the Sema Action Network,its free.
Old 06-22-2011, 10:09 PM   #17
bb62
CF Senior Member
bb62's Avatar
Quote:
Why did you change the injectors in your 95. The 405HP cars don't have the same injector issues as the earlier cars due to the different design.
bb62 is offline   Reply With Quote
Old 06-23-2011, 07:14 AM   #18
HammerZR1
CF Senior Member
HammerZR1's Avatar
I put the rebuilt FIC injectors in my '91 in November 2008 and they have performed flawlessly since then. Gets around 26 average MPG on the highway.
Idaho started emissions testing and the car passed with flying colors in May. The TSI test was used and the produced the following results:
HC PPM Idle...Reading 129...Limit 220
CO % Idle...Reading 0.01...Limit 1.2
Car had the following mods when tested:
Open AC Lid w/ K&N Filter
Flowmaster Cat-Back
Hope this info helps.
__________________
John Boyd
Nampa, Ideho
1991 ZR-1 #458 RED/BLACK 72k miles (SOLD)
1991 ZR-1 #473 RED/BLACK 37k miles (SOLD)
HammerZR1 is offline   Reply With Quote
Reload this Page 1990 Zr1 Fuel Injectors
Tags
1990, 1990zr1, corvette, emissions, fic, fuel, injector, injectors, install, lt5, mpg, part, requirement, tpi, zr1
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Emails & Password Backup
Search Engine Friendly URLs by vBSEO 3.5.2
