C4 ZR-1 Discussion General ZR-1 Corvette Discussion, LT5 Corvette Technical Info, Performance Upgrades, Suspension Setup for Street or Track
Code #61....o2 sensor?
Old 10-25-2017, 08:56 PM
biggiefl
biggiefl's Avatar
Default Code #61....o2 sensor?
Ran a scan on my 1990 ZR1 and code 61 was the only one. I was told driver's side o2 but wanted to clarify with the pros on this site.
Old 10-26-2017, 02:20 AM
WVZR-1
WVZR-1's Avatar
Received 2,254 Likes on 2,017 Posts
I believe you've likely been informed wrong! What was used as a scanning tool. Depending upon the scanner available diagnostics could vary. If just a code reader it's of no value.
'90 LT5 CODE 61 - Secondary Port Throttle Valve System
This would be a good read - there are others but with the Photobucket issues many snapshots aren't there.
http://www.corvetteactioncenter.com/...diagnosis.html
You don't have a FSM?
Quick Reply: Code #61....o2 sensor?
