Any Suburban/Yukon owners out there?
Now that my ZR-1 is in the hands of another lucky guy I need to get on to other cars' issues. I bought a 2005 Suburban with the AUTORIDE suspension system. The SERVICE RIDE CONTROL light is constantly on and I don't think the system works at all. The little "bags" in the rear look dried out and I don't know if the pump even comes on. The grounding point for several of the wires to the system looks pretty crappy. I don't know where the fuse is for the pump.
BUT...if this system is dead I do not want to pay for a new pump or those very, very expensive shocks. This is another bs GM pice of unneccesary gimmickry that is far more complex than it needs to be (even more than our adjustable vette system). SO...has anyone here replaced the autoride with a standard HD shock setup?
probably will find some advice on this over at fullsizechevy.com or gmfullsize.com . I don't see a reason why you couldn't put standard shocks in there, and have a PCM flash to eliminate the codes.
I have a 2500 Suburban with Autoride. You can't hear the pump, at least I can't on my truck. You would know if it is working however, because the rear should be significantly higher a coule mins. after pulling out of your garage. Have access to a trailer with a fairly heavy tounge? Put it on your hitch, as the rear sags, see if the Autoride will level it out. If not, you have a problem.
I've got an 03' 1500 2wd Suburban with close to 200Kmi. on it, and the original shocks.
I'm not sure which system is on it, and don't have the original build sheet or window sticker. But the (really large) rear shocks still do a good job of keeping it level, (with 500lbs. of gear on board usually.), even though I don't think the are the "air ride" type.
No codes or lights, but I sure would like to replace them as the overall ride quality has deteriorated.
Anything you guys might know, or to steer us to the right resource would be appreciated, TIA.
