(fs) 1991 zr1
(fs) 1991 zr1
I hate to, but i have to part with my black/black 1991 ZR1. $21,000
The bad first:
1. The pass. seat forward and rearward works fine except when you get the seat all the way back, then you have to "help" the seat forward again about an inch, then it works fine again.
2. There is a small scratch on the front bumper where the previous owner may have bumped a parking lot pole or something. The scratch has been touched up.
4. The CD player will not pull a CD into the player.
5. There is a small cut/scrape on the drivers side lower seat but the cut/scrape does not go through the leather. It is just a surface mark. It can be seen in the drivers seat picture.
6. There are small droplett stains on the outside of the lower plastic pannel where some battery acid got on the paint.
7. The engine paint is stained but not badly.
8. The paint is a 9 to 9 1/2 on the car.
9. Slight windshield delamination on original windshield. No rock chips.
10. There are small water droplett stains on the gray center console.
11. The stickers on the wheels are gone.
12. There are some small rock marks on the lower rocker pannels but not chips that go through the paint.
13. There is a very small spider web type paint blemish on the right side of the hood as seen in the picture. The blemish is just above the coolant holding tank.
The Good
1. The car has 21000 original miles on it. I bought it with 3,400 miles on it.
2. I replaced the old injectors with FIC rebuilt injectors, bosch II, less than 1000 miles ago. The originals will go with the car.
3. Checked all things under the plenum and all plastic hoses in good condition and flexable. All vacuum valves work as designed. Cleaned out mouse nest and pulled starter and all is ok. No wiring is chewed up by said mouse. Pulled vacuum on secondary system with a vacuume pump and it held perfectly.
4. Replaced spark plug wires with the red GM wires.
5. Both tops are with the car.
6. Bose receiver under the dash has been rebuilt by Dr. Dons.
7. Tires are in very good condition. Nitto 555 less than 1000 miles.
8. Front A arm bushings are replaced with poly bushings.
9. Pizza box is all there and comes with car. Also, original window sticker is in the box.
11. Compression test was run when new plugs were put in and the test results showed 210 psig +/- 3 psig.
12. Shocks are not leaking.
13. Engine has been dyno tuned by Corey Henderson at Henderson Performance Technologys. The results were 348 hp at rear wheels and 352 tq. on all original car. I have the dyno sheets to go with the car.
14. Corey had installed a coil over suspension but i have put the suspension back to stock.
15. Antifreeze has been completly flushed and replaced with green.
16. Brake fluid has been completly flushed through the calipers.
17. Everything is original except plug wires, fluids, plugs and front a-arm bushings.
18. Car has been lowered about an inch.
19. Interior is a 9 1/2 only because of the small cut on drivers seat and stains on the console.
20. I never retreived the build sheet but it can be seen folded up in the k-member.
21. I am the second owner outside of the dealership that owned it from the original owner to me. I was able to speak with the original owner before i bought the car.
23. The transmission fluid has been changed 2 times with the BMW M-5 oil.
24. The engine oil has been changed 6 times. I used Mobil 1 10w30. AC, oil and air filters also changed.
25. Oil has just been changed at 20360 miles. Bosch filter used and oil cooler oil changed also.
I have many pictures that I can e-mail or text to anyone. The car can be seen on Amarillo Craigslist under 1991 ZR1. There is a price difference you will see because forum members should get a better deal.
My asking price to forum members is $21,000.
Thanks for looking.
The picture in the avatar is the car after Corey lowered it at about 10,000 miles.
The bad first:
The Good
Thanks for looking.
Received 3,043 Likes
St. Jude Donor '05
Seller is a stand up A-1 guy, buyer will have no issues doing a deal or surprises.
No problem, you can always send me more and I will add them to that album
91 zr1 for sale
well, the pics are on the new photobucket but i dont know how to get them here. i will send pics to anyone who wants to see them via e-mail. see ya
Just go to your photobucket library and click one at a time each pic you want to post and copy the website link, then paste it into your new post, or original post. The copy/paste is done one pic at a time.
St. Jude Donor '05
Jeez Mike I hope everythings ok with you give a call sometime/pm
This is more than a standup guy gents
