C4 ZR-1 Discussion General ZR-1 Corvette Discussion, LT5 Corvette Technical Info, Performance Upgrades, Suspension Setup for Street or Track
I'm running too hot in Houston.
Old 06-25-2010, 08:58 AM
Rob 93ZR-1
Rob 93ZR-1's Avatar
Location: Fear causes hesitaiton...and hesitation will cause your worst fears to come true. Houston TX
Cruise-In IV Veteran
Cruise-In VII Veteran
Default I'm running too hot in Houston.
My digital temp hovers around 205 F until I turn on the AC. Then it goes up to around 215. That just normal town driving. If I hammer it, temp will spike to 240 range. I have to run the heater to bring it back down, which returns it to about 205. Fans are running. No obvious blockage in front of the radiator. Am I low on water or is my t-stat stuck or water pump weak? Car only has 35K miles on it.
Thanks guys.
Rob
Old 06-25-2010, 09:10 AM
FU
NCM Lifetime # 982
Support Corvetteforum!
FU's Avatar
Location: HOME OF THE FREE. BECAUSE OF OUR BRAVE. Babylon NY
St. Jude Donor '06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-'18-'19-'20
Take a good flashlight and look on the pass. side of the car between the radiator and A/C coil. Look at the entire rad.
Then pull out the rad and clean it out.
Is your car chipped for early on fans ?
Old 06-25-2010, 01:44 PM
Rob 93ZR-1
Rob 93ZR-1's Avatar
Fans turn on at 200, but I also have a fan override switch and they are on constant so that's not the issue. I will look closer at teh radiator this eve.
Thanks!
Old 06-25-2010, 08:11 PM
USAFPILOT
USAFPILOT's Avatar
I agree...240 is too high...mine runs at about 220 even under very agressive driving.
It is sticky hot here in H town already, that is for sure. I saw it will be 99F this week and the heat index factor is 105F.
Old 06-25-2010, 09:09 PM
pantera1683
pantera1683's Avatar
Mine acts exactly the way yours (OP) does. I'll be pulling the rad soon to replace it.
Old 06-25-2010, 10:07 PM
Peter Mahr
Peter Mahr's Avatar
Mine ran hot when idling for a long time in traffic. It never overheated but it never made me feel comfortable. 100 degrees and over half an hour in traffic was the limit.
I removed the radiator and it had some leaves but not enough to call a reason for the overheating. I replaced the radiator with a Dewitts ($500) aluminum radiator and now it never goes above mid range. Worth the cost if you are going to the effort of removing the stock one.
Old 06-26-2010, 04:38 AM
Goldcylon
Goldcylon's Avatar
What frank said. A lot of dirt and silt builds up between the fins as well. Plastic bags, leaves and other crap gets stuck in the shroud area as well.
Old 06-26-2010, 08:12 AM
Aurora40
Aurora40's Avatar
Just FYI, I would not think it's the t-stat, because if it was the car would not come back down in temperature.
Old 06-26-2010, 11:40 AM
Rob 93ZR-1
Rob 93ZR-1's Avatar
I saw some leaves in there and pulled them out. There wasn't much in there. I added about a liter of water to the expansion tank at the top of the engine bay. Then I sprayed water from the fan side thru the radiator and I will take it out this afternoon to see if any of that helped. I may spring for the trick radiator if this didn't solve the problem. I would like to get a lower temp thermostat if I get a new radiator, but I don't know if I really would need to.
Old 06-26-2010, 12:28 PM
XLR8TIN
XLR8TIN's Avatar
chip to turns fans on early, clean radiator(stuff in there you can not see until its out of car), lower thermostat, alum radiator all will help, fans running all the time will hurt because it will suck more stuff into radiator, GC is running stock radiator here in PHX as daily driver with no problems, I have a fluidyne and like it but $$$
Old 06-28-2010, 02:27 PM
guinnessdood
guinnessdood's Avatar
Here's what my radiator looked like at about 35K when I replaced it with a Ron Davis radiator...I would opt for a Ron Davis Radiator/Redline Water Wetter/Distilled H2O/180° thermostat. Of course that's just my COOL opinion... The 180° thermostat can be purchased at NAPA (P.N. THM 124) http://www.napaonline.com/Search/Det...124_0225195710
To I'm running too hot in Houston.
Quick Reply: I'm running too hot in Houston.
