You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Corvetteforum.com today!
Does any one know where to get 1990 ZR1 polyurethene motor mounts. Tried Rippie, White, Jeggs, Summit Racing and Energy Suspension to no avail. Also a Transmission mount.
The ZR-1 has a very unique motor mount (Oil filled I believe) and I don't know of any after market replacement. I would seach out an OEM. The ZR-1 has no transmission mount, the transmission bolts directly to the C-beam.
Scrrem
Scrrem
I know LT4s used the same motor mount but I havent seen anything but stock set ups.
as for moving the engine back and inch anything can be done but the motor mounts bolt into the engine k-frame so it would have to be a mod to the engine brackets on the engine I think. then the C-beam like tim said that would need moded as well.
