Corvette Forum
Go Back   Corvette Forum > C4 Corvettes, 1984 - 1996 > C4 ZR-1 Discussion
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
C4 ZR-1 Discussion General ZR-1 Corvette Discussion, LT5 Corvette Technical Info, Performance Upgrades, Suspension Setup for Street or Track
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 11-16-2009, 07:31 PM   #1
Smiler
Junior Member
Default aux fuse panel
Hi,
I am looking for the aux fuse #5 under the passenger hush panel. All I can find is the 1-4 aux fuse panel. I have a 90 model, manual states 2 aux fuse panels. Can someone help me locate this other panel
Smiler
Smiler is offline   Reply With Quote
Old 11-16-2009, 08:21 PM   #2
65ZR1
CF Senior Member
65ZR1's Avatar
What are you trying to fix? Im not positive but I think there is another in line fuse holder for the underhood lamps. Its located in the engine compartment at the front.
65ZR1 is offline   Reply With Quote
Old 11-16-2009, 10:03 PM   #3
Smiler
Junior Member
Quote:
I am troubleshooting the night time orange lighting. The INST fuse in the main fuse panel and INST Fuse in the seconary fuse panel under the passenger hush panel according to manual. But now I am not sure if the 90 model has two secondary fuse holders. My manual is for 91.
Old 11-17-2009, 09:44 AM   #4
Goldcylon
Goldcylon's Avatar
On the 91 they are side by side as it shows in your 91 manual. It’s entirely possible that the 90 has only one of these aux fuse panels, One of the add on accessories for the 91 was a power wire under the console to power an accessory like a cell phone. That power comes from the 2nd block and I know that MY90 C4s do not have this power wire.
I had a similar problem in my 91 with the loss of almost all the orange nightglow. Solution was to replace the incandescent light driver module that is mounted under the dash on the top of the steering wheel column. You will need to drop the driver’s side hush panel and the hush pane skeleton to get to it. Good luck
Goldcylon is offline   Reply With Quote
Reload this Page aux fuse panel
Tags
1967, 91, audio, aux, bose, c4, c6, corvette, forum, fuse, fuses, location, panel, pannel, stereo
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
I'm a moron.... bogus C4 Tech/Performance 22 11-21-2004 06:24 PM
Horn Not Working '90 - Fuse? Spinman C4 Tech/Performance 11 03-30-2004 12:34 PM
Problems with PIE GM10-AUX and COR-HAR installation Go FasTA Audio/Electronics 9 02-05-2004 08:11 PM
Wideband O2 Sensor severe-1 C4 Tech/Performance 13 10-13-2002 11:29 PM
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
