Corvette Forum
Go Back   Corvette Forum > C4 Corvettes, 1984 - 1996 > C4 ZR-1 Discussion
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
C4 ZR-1 Discussion General ZR-1 Corvette Discussion, LT5 Corvette Technical Info, Performance Upgrades, Suspension Setup for Street or Track
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 11-15-2009, 08:06 PM   #1
timbradley26
CF Senior Member
Default charging system ????
i have installed a new bat. and alt. i get a reading of 3.8 at the bat when running . but when i turn it off i get a no start. i connect a bat charger and she will start . does that mean my new bat could be bad or is there something else i am missing help
timbradley26 is offline   Reply With Quote
Old 11-15-2009, 08:07 PM   #2
timbradley26
CF Senior Member
sorry it should read 13.8
Old 11-15-2009, 10:53 PM   #3
81c3
CF Senior Member
81c3's Avatar
Voltage sounds crrect to me. The no start sounds like a bad connection somewhere. Why did you replace the battery and alternator to begin with.
81c3 is offline   Reply With Quote
Old 11-16-2009, 01:17 AM   #4
timbradley26
CF Senior Member
i was cking the charging system on this car . just bought it and it had sat in a barn for 5yrs. needed a new bat . when i cked the voltage with the car running it was 13.2 which i knew wasnt right .plus the alt was a little noisy. i pulled the plenum and did new coils ,wires and cked all the secondary vac system so i fugured while i was at it just replaced the alt. too .
Old 11-16-2009, 06:41 AM   #5
Paul Workman
CF Senior Member
Paul Workman's Avatar
Default 13.2-8 = a tad low
A fully charged and warm battery will have about 13.6-8 volts across the terminals, if the alt is charging correctly. 13.2 or on a new battery and -
1) either the battery is severely discharged (put a charger on it and after it is charged, start it and re-measure and see if it isn't up around 14.7 initially)
2) the regulator is bad, OR there is a connection issue either with the field coil connection (that little plug on the back of the alt) or there could be a ground issue.
Gotta run, but the FSM and a VOM will point you to a connection issue. My guess is the voltage reg.
P.
Paul Workman is offline   Reply With Quote
Old 11-16-2009, 06:07 PM   #6
81c3
CF Senior Member
81c3's Avatar
13.8 is perfectly normal for a voltage reading across the battery terminals if the battery is in good shape. The alternator wont need to raise the voltage via the field coil if the battery is healthy. A fully charged battery reads 12.4 to 12.7 when sitting on the bench. If the battery is new, the charging system wont bump it up hardly at all, especially if theres no current draw.
When the engine is running, pull on the headlights and switch on some accessories, see if the voltage increases. If it does, the alternator is charging properly.
I would bet on a bad cable connection at the starter terminal now that you say you had the plenum off and was under there dinkin' around....or a bad battery cable connection either at the + or - terminal. Also check the 12V feed wire on the back of the alternator and see if its tight as well as the purple wire to the starter itself.
Old 11-16-2009, 06:33 PM   #7
timbradley26
CF Senior Member
thanx for all the help guys i will ck it all after dinner
Reload this Page charging system ????
Tags
1982, 1984, c4, charging, corvette, diagram, service, system
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
Charge System Fault Message CorvettePartsBob C5 Z06 Discussion 57 10-20-2005 10:24 PM
ahh my charging system still sucks! will this crazy idea work? radwebster C4 General Discussion 13 04-12-2005 05:32 PM
Charging System Fault on DIC hokievette03 C5 Tech 20 08-12-2003 04:37 PM
Need help with “ Charging System Fault” Charley Hoyt C5 Tech 10 12-13-2002 02:11 PM
Has anyone seen "Charging System Fault" on the DIC before???????? BIG99 C5 Tech 16 09-02-2002 08:33 PM
Mid Year Charging System problem ARed64 C1 & C2 Corvettes 9 03-18-2002 12:34 PM
Charging system fault and DIC codes mozin C5 Tech 9 09-19-2001 05:16 PM
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
