Corvette Forum
Go Back   Corvette Forum > C4 Corvettes, 1984 - 1996 > C4 ZR-1 Discussion
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
C4 ZR-1 Discussion General ZR-1 Corvette Discussion, LT5 Corvette Technical Info, Performance Upgrades, Suspension Setup for Street or Track
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 11-08-2009, 07:26 PM   #1
vettn71
CF Senior Member
vettn71's Avatar
Default Side Bolsters
The side bolsters on both seats appear to out of order. The pumps work fine, it seems, as they pump up the lumbar support. Is there anything else besides the bolsters that can be checked or replacement the only option? Are they still available and from where?
Thanks in advance
Jim
As a footnote, these were supposedly replaced three years ago by a dealership in CA. Don't see why they would go bad so soon
vettn71 is offline   Reply With Quote
Old 11-08-2009, 08:01 PM   #2
ZRWHAT
CF Senior Member
ZRWHAT's Avatar
The side bolsters or wings as they call them are controlled by a rocker switch located at the very front of the seat by the outside corners, they are facing the dashboard and just below the front seat cushion, left side switch would be to the left corner of the seat, right side would be towards the right corner of the seat.
The lumbar support is controlled by a pump that fills all 3 bladders, the side bolster has a mechanical motor that moves them in or out, depending on your level of comfort and fit. This is why they call them wings..
What usually goes bad are the diaphrams in the lumbar support motor, once they go they will not pump up the lumbar bladders.
Hope this helps
ZRWHAT is offline   Reply With Quote
Old 11-08-2009, 09:14 PM   #3
blkzr1
CF Senior Member
blkzr1's Avatar
Default bolsters
hi, my pass. side bolsters did not work on my 1991 zr1. they were stuck in the most open position or widest setting. i tried the switch on the front of the bottom of the seat several times over the years with no results. one day i decided to try it again and i asked my wife to work the switch while i pressed inward on the bolsters. i was able to get the bolsters to begin to work again. i worked them in and out several times after freeing them up and now they work as designed. i dont know if they were frozen up or over centered and just needed a little help. you might give this a try, it may work. see ya
blkzr1 is offline   Reply With Quote
Old 11-09-2009, 09:13 AM   #4
Aurora40
CF Senior Member
Aurora40's Avatar
Quote:
On a '90, which is what his avatar is, they are on the seat cushion.
On the driver's seat, I believe it's on the left side. There is one switch for the seatback angle, and one that controls the wings. As said, the lumbar pump does not move them.
Aurora40 is offline   Reply With Quote
Old 11-09-2009, 10:00 AM   #5
ratmotortom
Platinum Supporting Vendor
ratmotortom's Avatar
I have a great old article I saved from Vette Vues magazine on this topic. Drop me a note and I can fax or email it to you.
ratmotortom is offline   Reply With Quote
Old 11-10-2009, 08:47 PM   #6
corvette95
CF Senior Member
The 94/95 seats have a connection on the bottom of the drivers seat has two connectors that can be plugged upbackwards causing something like that.
corvette95 is offline   Reply With Quote
Reload this Page Side Bolsters
Tags
bolster, bolsters, c4, c5, corvette, replacement, seat, side, switch
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
Why does GM do this to Corvette owner's? 2000Corvette C5 General 63 07-12-2005 03:54 PM
Seat Side Bolsters DanS711 C4 General Discussion 11 02-07-2005 10:21 PM
What to use to stop seat wear on the drivers side seat baseball22 C4 General Discussion 21 05-06-2002 06:47 PM
WTF is wrong with GM side bolsters PeterK C5 Tech 15 08-10-2001 01:49 PM
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
