Corvette Forum
Go Back   Corvette Forum > C4 Corvettes, 1984 - 1996 > C4 ZR-1 Discussion
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
C4 ZR-1 Discussion General ZR-1 Corvette Discussion, LT5 Corvette Technical Info, Performance Upgrades, Suspension Setup for Street or Track
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 02-18-2002, 02:01 AM   #1
Quasar Z
CF Senior Member
Quasar Z's Avatar
Default Porting Plenum and Inj. Housings
Guys,
I have a problem that I think many of us are running into. It is called the '02 Z06. One of my friends has one that is putting out 372 RWHP with just an airbox, bigger injectors and tuning. He is lipping off about how he will walk my ZR1. His car ran 11.83 at 117 on a very cold day. It is usually a low 12 second car.
I have to remove my plenum to put a new vacuum harness on and was wondering if anybody here has ported their plenum and injector housings themselves. I would love to have Mark Haibeck do it, but $2800 is not currently in the budget.
If anyone has attempted this or thought of it, please let me know what you have done. Pictures would be great if they are available. Help me save some dignity and pick up some additional HP before this race. My current mods are in my signature. Thanks for the help.
Quasar Z is offline   Reply With Quote
Old 02-18-2002, 09:57 AM   #2
FastZR1
CF Senior Member
FastZR1's Avatar
Default Re: Porting Plenum and Inj. Housings (Quasar Z)
I can't help you on the porting, but I just wanted to say, that is a nice looking Z you have! :yesnod:
FastZR1 is offline   Reply With Quote
Old 02-18-2002, 10:24 AM   #3
ZR1
CF Senior Member
I did a whole writeup on how to do the housings on the ZR-1 Net. When the net was switched over to the NCM the writeup got lost in the fray. Anyway, I will check at home for the pics I did for it and try and get you a post on the how to tomorrow.
Old 02-18-2002, 11:20 AM   #4
Rkreigh
CF Senior Member
Default Re: Porting Plenum and Inj. Housings (ZR1)
how much is does this run. I am interested in just doing the heads, intake, and inj housing on my 90. I think DRM may have ported the inj housings and intake already, but I'm interested in going to a siamese configuration.
also, I've heard of eliminating the secondary plates and how this isn't a good idea for low end torque. but with the 4.10 gears, I get up to speed quick and wheelspin is a problem. is the chip reprogrammed to just fire both injectors all the time. haven't seen much discussion of getting rid of the secondaries but I think I may want to do that on my car if it would gain some upper end power without sacrificing too much low end. may be a really bad idea, not sure.
I think greg V. is the man I will go to for the porting. anyone better/cheaper??/ greg seems VERY reasonable and nice to deal with.
is pulling the engine the easiest way to get the heads off???
thanks ZR1!!! et all :blueangel:
Rkreigh is offline   Reply With Quote
Old 02-18-2002, 12:18 PM   #5
ZR1
CF Senior Member
Default Re: Porting Plenum and Inj. Housings (Rkreigh)
DRM typically does the extrude/hone of the injector housings and plenum. Now don't get me wrong, I am a big fan of extrude/hone, but it doesn't do the same thing as porting does. Basically, it makes what you have more efficient. What it doesn't do is reconfigure, if you will, the intake runner like a port job does.
As far as a "siamese" configuration, it all depends on what you mean by siamese. If all you are intending to do is to remove the bifucation between the runners in the plenum, then that is no big deal. However, if you are taking about removing the metal between the runners and rewelding it, then you are wasting your time and money.
OK, let's just do some reasoning here. A 350 motor can use only X amount of air. If you have the capacity to flow that amount of air, no matter what you do you aren't going to flow any more. There is plenty of breathing ability in the LT5 to flow all the requirements of a 350 with just a bit of porting. Actually, all you have to do is to take the primary runner in the head and enlarge it from 1.26" to 1.33". The secondaries are not touched.
For the 350 motor Greg is about the cheapest there is out there.
You can leave the motor in and do them easily enough. You will have to remove the brake booster on the driver side. On the passenger side, the last two head bolts cannot be taken out fully when removing/replacing. You need someone to hold the bolts out as far as possible and then you can pull the head off. The hardest part of the whole top end job is timing the cams with the motor in the car. You will have to make your own degree wheel that you can tape to the dampener. Also, you will have to grind off some of your socket to fit between the frame rail and dampener so you can turn the motor. Some people will take the whole cooling pack out to get to the bolt in the dampener. If you do that, just remove the whole pack in a limp. You will need to remove the oil lines, cooling lines, and a/c lines before taking the pack out.
I am just trying to tell people of screwups before they do them. I have had my share.
Old 02-18-2002, 01:31 PM   #6
Quasar Z
CF Senior Member
Quasar Z's Avatar
Ed - Thanks for the compliment
ZR1 - Thanks for looking for the information. Do you really think 25 RWHP is a reasonable expectation out of the relatively simple porting job?
Old 02-18-2002, 01:58 PM   #7
Jeffyvette
CF Senior Member
Jeffyvette's Avatar
Send a message via AIM to Jeffyvette
Ron,
I would check with Bill Krishoofer in Mt Washington, KY he is the US rep for Jeal Ind.He was involved with the design of the LT-5. He did my plenium and injector housing after Lingenfelter did a crappy job on them. Don't use Lingenfelter :mad . I don't have his phone number with me but I bet someone here will have it.
Jeffy'
Jeffyvette is offline   Reply With Quote
Old 02-18-2002, 02:06 PM   #8
FU
NCM Lifetime # 982
St. Jude Donor '06-'07-'08-'09-'10-'11
Support Corvetteforum!
FU's Avatar
Location: Big government & Blue States stink. BABYLON NY
Default Re: Porting Plenum and Inj. Housings (Jeffyvette)
Billy Kirchhoffer's phone # 502-921-1046
FU is offline   Reply With Quote
Old 02-18-2002, 02:49 PM   #9
USAZR1
CF Senior Member
USAZR1's Avatar
Default Re: Porting Plenum and Inj. Housings (FrankUrbinati)
ZR1 is also a Jeal rep and his portwork is excellent,too. His prices are very reasonable,also.
DRM was sending their top end parts to ExtrudeHone back in the 1990's but now they are having Greg Van Deventer do the majority of their LT5 portwork.
USAZR1 is offline   Reply With Quote
Old 02-18-2002, 04:50 PM   #10
Rkreigh
CF Senior Member
Default Re: Porting Plenum and Inj. Housings (USAZR1)
I think vette doctor may use greg too.
OK, just ball park (+/- a couple hundred buck), porting the heads, remove some of the divider at the top of the intake, and match port the injector housings, what would the approx cost be??? I would also want to refinish the cam covers and intake too (mine are pretty grungy).
ZR1, I would like a quote from you along with what HP/torque I might get from a stock short block (not ready for a 368 just yet).
please contact me in private.
ron_kreigh@hotmail.com thanks.
Old 02-18-2002, 05:13 PM   #11
ZR1
CF Senior Member
Right now I guess I am about the cheapest for plenum and injector housings work. I didn't realize how much cheaper until recently. I gotta cure that. Greg is the cheapest on the head side of things. For a 475 motor he is just rock bottom.
With the top end from me it includes porting polishing of the heads, injector housings, and plenum. If you want the plenum "Siamesed", it is an exra $1600.00. Also included are hardened valve seats, bronze guides, Teflon seals, and locks installed. Competition valve job with radius cuts to all valves and seats as well as pressure testing of the valve springs and replacement (at ccustomer cost) if necessary. Finally, flow bench testing of the heads prior to and after job completion to include a flow comparison sheet. Total cost is $3,500.00.
Old 02-18-2002, 05:29 PM   #12
Quasar Z
CF Senior Member
Quasar Z's Avatar
ZR1,
Please e-mail me privately. I would like to gets some details from you. E-mail is mquinn@execpc.com. Thanks.
Mike
Old 02-18-2002, 10:55 PM   #13
ZR WON
CF Senior Member
ZR WON's Avatar
Jeffy:
Not to pick and nits but if you are so unhappy with LPE, why do you have *them* in your sig as modifying your car??? Why don't you have it Billy Kirchoffer(sp) or Jeal modified???:)
ZR WON is offline   Reply With Quote
Old 02-18-2002, 11:29 PM   #14
LT5
CF Senior Member
LT5's Avatar
So how much HP can be realized from a top end job?
LT5 is offline   Reply With Quote
Old 02-19-2002, 12:10 AM   #15
92 ZR1
CF Senior Member
92 ZR1's Avatar
That would be about 900 6 packs of beer for us MS & AL folk. :cheers:
92 ZR1 is offline   Reply With Quote
Old 02-19-2002, 09:27 AM   #16
Rkreigh
CF Senior Member
thanks ZR1!!! that is way cheaper than I thought. Is the siamese intake a good move with only a stock short block??? my inj housing and intake have already been ported by DRM, but I think they just do some pretty minor cleanup for the 450 kit. car just doesn't feel like 450 (108 in the qtr at BG).
I'm looking for a good ZR1 mechanic that can properly retime the cams. I may just go ahead and pull the engine and ship off whatever needs freshening up. I plan to first test the leakdown test, if all is OK, pull the top end off and use the factory short block until it needs a rebuild. every one talks about the high cost of the LT5 but if it lasts as long as I think, it's a bargain!!!
I'm looking to get as close as I can to 500 hp with a factory bottom end and cams (a bit ambitious, I know), and then add another 150 shot of squeeze to get to 650. that is as much as I feel I can hope to hook up on drag radials. anything more than that, I will probably just tear up the tranny and drivetrain.
looking for that big top end charge. thanks
Old 02-19-2002, 10:43 AM   #17
Tyler Townsley
CF Senior Member
According to LPE a leakdown test on a LT5 is an iffy thing due to the lifters holding oil and causing false readings. At the time they said they no longer used leakdown tests on LT5 for any diagnosis.
Tyler
90ZR1
87 ZR1 EX5014
Tyler Townsley is offline   Reply With Quote
Old 02-19-2002, 11:59 AM   #18
Jeffyvette
CF Senior Member
Jeffyvette's Avatar
Default Re: Porting Plenum and Inj. Housings (Tyler Townsley)
ZR-won,
I reason I have kept the Lingenfelter in the sig is two fold. 1. So people will ask if I like his work and I can let them know. 2. Because if I put pictures of my motor on the web everyone will see the Lingenfelter the Ba%#@ards engraved in the top of my plenum and again ask my thoughts.
Jeffy'
Old 02-19-2002, 03:38 PM   #19
USAZR1
CF Senior Member
USAZR1's Avatar
Tyler
90ZR1
87 ZR1 EX5014
I've often wondered why the tuners didn't like to do leakdowns on LT5's. You just answered that question,Tyler. The explanation does seem a little strange,though. What's the big difference between LT5 hydraulic lifters and others?
Old 02-19-2002, 03:54 PM   #20
ZR WON
CF Senior Member
ZR WON's Avatar
RKreigh:
YOu need to remember that BG is a notoriously slow track for mph. When my ZR-1 was stock the best I could do there was 13.07@108. I took the car to IRP in Indy, IN(good track) and ran 12.8s@111.
After I installed the 4.10s, headers and exhaust my best time in BG(I was living there at the time, my 'home' track if you will) was a 12.8@111!!!(you can imagine how happy I was at that point) I took it back to IRP and ran a 12.28@115! After the plenum/injector housings were ported I ran at BG once in May and turned 12.60@113mph. I again trekked to IRP last fall and turned 12.09 at over 118mph! If they hadn't just re-concreted the starting line I could have put it in the 11s(best 60ft time was 2.01) In short, Beech Bend sucks and 108 at BG is probably really 111-113 on a good track; your car probably isn't as down on power as you think.
[Modified by ZR WON, 12:58 PM 2/19/2002]
Reload this Page Porting Plenum and Inj. Housings
Tags
bill, corvette, deventer, end, greg, housing, housings, injector, kirchoffer, lt5, plenum, ported, porting, siamesed, teardown, top, van
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
418 Update LoTu5 C4 ZR-1 Discussion 14 03-13-2005 06:23 PM
Putting a few mods on 91 ZR-1 z76232 C4 ZR-1 Discussion 25 08-15-2004 07:28 AM
new track times today in my ZR-1... i'm impressed FastMatt2 C4 ZR-1 Discussion 28 02-06-2004 05:05 AM
++ Porting the stock '95 LT5 95ZR1#418 C4 ZR-1 Discussion 16 12-15-2003 04:25 PM
++++ Port & Polish Questions 95ZR1#418 C4 ZR-1 Discussion 34 12-08-2003 01:26 AM
And another thing.. Someone tell me how to... BiZ C4 ZR-1 Discussion 9 08-02-2002 01:43 PM
Pics of my car on the dyno... VetteBabe1 C4 General Discussion 15 05-21-2002 05:42 PM
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
