Corvette Forum
Go Back   Corvette Forum > C4 Corvettes, 1984 - 1996 > C4 ZR-1 Discussion
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
C4 ZR-1 Discussion General ZR-1 Corvette Discussion, LT5 Corvette Technical Info, Performance Upgrades, Suspension Setup for Street or Track
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 02-16-2002, 12:15 PM   #1
FoolCrzy
CF Senior Member
FoolCrzy's Avatar
Default 1990 zr1 Warranty engine replacement?????
Hi guys, I'm looking at a ZR1 that seems really cheap.. The curent Owner says the previous owner said the engine was replaced under warrnaty or a recall..This apparently happened not too long into the cars life. Does anyone know anything of this. Any help is appreciated.. Thanks
FoolCrzy is offline   Reply With Quote
Old 02-16-2002, 04:23 PM   #2
Jeffvette
CF Senior Member
Jeffvette's Avatar
Location: No more yankee my wankee, the Donger is tired!
Default Re: 1990 zr1 Warranty engine replacement????? (FoolCrzy)
If something went wrong with the engine, you had the option under warranty for the whole engine to be replaced, or wait while yours was repaired back at Mercury Marine. I have yet to come across a car that had the whole engine changed.
What's the vin number on the car?
Jeffvette is offline   Reply With Quote
Old 02-16-2002, 05:28 PM   #3
FoolCrzy
CF Senior Member
FoolCrzy's Avatar
Default Re: 1990 zr1 Warranty engine replacement????? (Jeffvette)
1G1YZ23J0L5801097
Old 02-16-2002, 06:05 PM   #4
Jeffvette
CF Senior Member
Jeffvette's Avatar
Only the real early ones were put on hold from the factory due to a problem with cold weather issues.
More than likely the car had a defect, or the owner just didn't understand the limits of the engine.
Old 02-16-2002, 06:59 PM   #5
04Z16
CF Senior Member
CI 3-4-5-6-7-8-9-10 Veteran
04Z16's Avatar
You might want to check CarFax. There is a possible odometer rollback on the title issued from Ohio.
04Z16 is offline   Reply With Quote
Old 02-16-2002, 07:06 PM   #6
baddmann
CF Senior Member
baddmann's Avatar
FoolCrzy,
I was reading your post and I thought I would help out by running the carfax for you. It does show a "Not Actual Mileage" title issued. I forwarded the results to your aol email acct.
Hope this helps.
:cheers:
baddmann is offline   Reply With Quote
Old 02-16-2002, 07:24 PM   #7
FoolCrzy
CF Senior Member
FoolCrzy's Avatar
Default Re: 1990 zr1 Warranty engine replacement????? (baddmann)
Baddmann and 96Grandsport,
Thanks for the effort, I have the carfax also. I have heard that if an engine is replaced under warranty, under certain circumstances, They will roll the odometer to zero. The point when the "not actual Mileage" appears, the car has under 20,000 miles. The owner says there is a sticker on the door jamb that saysthe odometer was rolled back to zero and "by state law don't remove this sticker". I'm wondering if this is the case. Can a chevy dealer look this up??
Old 02-16-2002, 11:08 PM   #8
04Z16
CF Senior Member
04Z16's Avatar
Ron,
You might want to check up in the C5 for sale section and ask either Ken Fitcher or Karl Johanson or even Monica at Maxie Price and they might be able to tell you if it is true or not. Hope thats the case because it sounds like a good car.
Leo
Old 02-17-2002, 12:58 PM   #9
FoolCrzy
CF Senior Member
FoolCrzy's Avatar
Default Re: 1990 zr1 Warranty engine replacement????? (96GrandSport)
Leo,
Thanks a lot.
Ron
Old 02-18-2002, 08:55 AM   #10
phrogs
CF Senior Member
phrogs's Avatar
I do know that some of the early 90's had the engines removed and replace due to the camshafts not being ground correctly and gm got all the cars with these problems before they made it to the public.(reference "The heart of the beast")
But this paricular car is ScottyD's and im sure the car is fine id jump on that one after a test drive and a good walk around, seems like a good deal to me.
phrogs is offline   Reply With Quote
Old 02-19-2002, 06:33 PM   #11
BOBA VETT
CF Senior Member
BOBA VETT's Avatar
in the black book on page 92 last paragraph it talks about the motor repair or replacement
BOBA VETT is offline   Reply With Quote
Old 02-19-2002, 07:28 PM   #12
95ZR1
CF Senior Member
95ZR1's Avatar
Hi all!
I bought my 95 ZR1 about 2 years ago from a dealer.
I also got a carfax report, clear.
I then got the GM warranty history which reported that the
engine was totally replaced at ~25,000 miles, but not why.
I found out where the swap was done (another chevy dealer)
but they wouldn't tell why (customer confidentiality.)
Moral- engines were replaced, probably too complicated (or costly) for the
dealer to repair. Maybe liability issues. I was bummed at first,
but then figured that I just have a newer engine (Dunn heads?)
95ZR1 is offline   Reply With Quote
Old 02-19-2002, 08:01 PM   #13
David-F
CF Senior Member
Default Re: 1990 zr1 Warranty engine replacement????? (95ZR1)
Yes there was a hold in early 90 for cam problems ( I heard there was a problem with one of the workers reving cold engines and damanging the cams) but don't believe that none ever made it out of the dealers I'm pretty sure we had one delivered to a customer out of state that may have had a cam problem and if that be the case I'm sure that car would have gotten a replacement engine, unless for some reason they wanted to wait for who knows how or oreder up a complete engine and swap it out. So I would not be suprised if it has a replacement engine also don't forget many dealers out there did not know what they were doing so they may have just replaced an engine for who knows what may not even have had a problem.
David Fulcher
David-F is offline   Reply With Quote
Old 02-19-2002, 09:46 PM   #14
FoolCrzy
CF Senior Member
FoolCrzy's Avatar
Default Re: 1990 zr1 Warranty engine replacement????? (David-F)
Thanks for the help guys, that sheds some more light on the situation...
:cheers:
Old 03-02-2002, 06:20 PM   #15
ScottyD
CF Senior Member
ScottyD's Avatar
HEy eveyone sorry about the carfax showing no accutal miles I was a little mad about this my self when I found out about it .When I bought the car I never ran the car fax on it i wanted something fast so I bought It and loved it until I drove the c5 then I had to get one of them ,next step is to but a Zo6 in a few years .I do have a set of 90 ZR1 rims on its way if this changes anything let me know
ScottyD is offline   Reply With Quote
Reload this Page 1990 zr1 Warranty engine replacement?????
Tags
1990, c4, carfax, corvette, engine, motor, replacement, zr1
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
Are you still legal (in Texas) without the pre-cats? Tiger Shark C5 Tech 38 09-28-2010 01:46 PM
Heads & Cam vs. new smog laws effictive 1/1/02 vetterdstr C5 Tech 40 01-04-2002 12:15 PM
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
