Corvette Forum
Go Back   Corvette Forum > C4 Corvettes, 1984 - 1996 > C4 ZR-1 Discussion
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
C4 ZR-1 Discussion General ZR-1 Corvette Discussion, LT5 Corvette Technical Info, Performance Upgrades, Suspension Setup for Street or Track
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 02-15-2002, 12:55 PM   #1
xsmph
CF Senior Member
xsmph's Avatar
Default "X" pipe or "H" pipe
Have any of you got any experience with either one on a ZR-1.. any sotp difference.. I know what has been said on the"X" vs. "H" pipe, but i'm looking for first hand experience on the Zr-1..
What are the Big Boys running?
xsmph is offline   Reply With Quote
Old 02-15-2002, 04:43 PM   #2
GTB/ZR-1
CF Senior Member
GTB/ZR-1's Avatar
Default Re: "X" pipe or "H" pipe (xsmph)
Julio,
you are the big boy when it comes to ZR-1's...
Aren't you just going to use the resonator from a Tri-Flo or similar? I think that should do you fine without needing to go to a customized type system. My .02...
George
GTB/ZR-1 is offline   Reply With Quote
Old 02-15-2002, 05:25 PM   #3
xsmph
CF Senior Member
xsmph's Avatar
Default Re: "X" pipe or "H" pipe (GTB/ZR-1)
George, thanks for the complement...I currently have a 3" with no cats or resonators and I have the "H" pipe. I'll be replacing the mufflers with the 3" straight thru magnaflow, and part of the rear piping to hook up to the mufflers, so all comes even.
I was running the super turbo Mufflers Lt-1 style with the chrome square tips. Problem is these mufflers, although quiet, are 2-3/4" inlet and 2-1/4" inside!!!, the outlet is 2" or so before the square tips. So I figure I might pick up a couple of ponies by changing to the 3" straight thru design... Are you running the resonator on your Tri flow?
P.S you are also one of the BIG BOYS!!!
Old 02-15-2002, 06:43 PM   #4
RatRacer
CF Senior Member
RatRacer's Avatar
Curtis Ward is running a 3" system with a X-pipe.
RatRacer is offline   Reply With Quote
Old 02-15-2002, 11:18 PM   #5
USAZR1
CF Senior Member
USAZR1's Avatar
Default Re: "X" pipe or "H" pipe (Cam Potter)
Julio,if I remember correctly,the Vette Doctors have installed & dynoed both on ZR-1's. You might give Carmen a call and see what he says.
Clint Hooper
LT5 Registry #001 http://www.LT5Registry.com/
USAZR1 is offline   Reply With Quote
Old 02-16-2002, 01:56 AM   #6
GTB/ZR-1
CF Senior Member
GTB/ZR-1's Avatar
Default Re: "X" pipe or "H" pipe (USAZR1)
Julio, I'm running a plain 'ol Tri-Flo system, w/ resonator intact... I think you'll more than likely make out better w/ an X, instead of an H...
Old 02-16-2002, 08:26 AM   #7
Rkreigh
CF Senior Member
in theory the X would work a bit better. I don't think the different would be that great. the X would hopefully route the gases/pulses between pipes more efficiently. I don't think either one will be significantly better and packaging might be the biggest issue.
On my old BB chevy, I gained 7 hp by adding the H. it wasn't easy to do an X pipe because of the spread of the pipes. on the C4 either one should be easier to implement. I wonder about how the sound will differ too. I'm betting the difference between the two would be less than 5 hp.
Rkreigh is offline   Reply With Quote
Old 02-16-2002, 08:30 AM   #8
Jeffyvette
CF Senior Member
Jeffyvette's Avatar
Send a message via AIM to Jeffyvette
Now I don't consider myself a big boy of this group, but I run a merge pipe it is like an x-pipe but not as extreame. It equalizes the pressures between the banks with better flow. The NASCAR guys all run the merges and that must mean something. If you have an intrust in them my mechanic makes them and ships them, his name is Rich(the owner) at Kimble Motorsports in Boise, ID 208-323-9950.
Jeffy'
Jeffyvette is offline   Reply With Quote
Reload this Page "X" pipe or "H" pipe
Tags
c4, corvette, pipe, vette
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
I need an x-pipe, factory H-pipe went bust TheHammer C5 Parts for Sale/Wanted 16 04-05-2005 02:29 PM
X-pipe or H-pipe? stingry C3 Tech/Performance 11 08-07-2004 09:18 PM
does anyone make an x-pipe or h-pipe for an 1993 ZR-1 Usa1-Zr1 C4 ZR-1 Discussion 10 03-25-2002 05:39 PM
X-pipe or H??? M.D.A.2 C4 Tech/Performance 11 02-16-2002 06:23 PM
X-Pipe vs. H-Pipe Blake-73 C3 Tech/Performance 15 12-18-2001 06:47 AM
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
