should be a good race. both cars will be difficult to launch and hook up and should be capable of similar times. Paul D I think is in the low 10s. Norm should be too. the henessy runs low 10s. great race. let the twin turbos spool!!! :p:
Location: Big government & Blue States stink. BABYLON NY
Re: Viper Guys giving Norm a Hard Time (Rkreigh)
Ron, The FAST unit will help these twin turbo car's out quite a bit. IE; lean up for real quick spool then richen the mixture as pressure build's for a safety margin. Wideband to run super high octane leaded fuel. So moderate to high boost won't bring on the dreaded detonation syndrome. But then Lot's of trouble with traction and half shaft's flying.
Take's ALOT of leaded gas to kill the FAST wideband 02 sensor. And yes the wideband's are expensive. The tuning ability of the FAST unit's are fantastic. It allow's much more tunability and a wider margin of safety. Give Precision or Jack a call to find out. Precision give's you the complete harness (no butchering of your harness) and a real good start-up program.
