Corvette Forum
Go Back   Corvette Forum > C4 Corvettes, 1984 - 1996 > C4 ZR-1 Discussion
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
C4 ZR-1 Discussion General ZR-1 Corvette Discussion, LT5 Corvette Technical Info, Performance Upgrades, Suspension Setup for Street or Track
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 02-12-2002, 05:43 PM   #1
ZR1991
CF Senior Member
ZR1991's Avatar
Default Oil Leaks From Exhaust Bolts?
I know this was discussed previously some time ago, but I could use some help/clarification.
My car leaks oil at the exhausrt manifold, more on the left that the right, primarily when it is put away for a week or more, which is often. I have understood that some of the exhaust bolts/studs penetrate oil galleries and leak over time. My questions:
1. The bolts are obviously not easy to get at, but I can see the leaks (I think) from under the car. Exactly which bolts are involved in the leaking?
2. Different from right and left, or the same?
3. What is the easiest way to get at them?
4. What is the most useful fix? I assume a sealant? What kind?
Many thanks, and anything else I have forgotten?
ZR1991 is offline   Reply With Quote
Old 02-12-2002, 07:13 PM   #2
ZR1
CF Senior Member
Default Re: Oil Leaks From Exhaust Bolts? (ZR1991)
Hopefully, it is at the stud. It is located about in the center of the header flange. You can tell which one it is by it having a 13 mm nut on it rather than it being a bolt with a spacer.
Getting to it may be easy, may be hard, depending on if the nut is secured to the stud or if the nut comes off the stud. If you are lucky, when you try to remove the nut, the whole stud will come with it. If so, use some Loctite 565 on the stud and replace it. If not then you will have a dickens of a time getting the stud out.
ZR1 is offline   Reply With Quote
Old 02-12-2002, 08:14 PM   #3
8388
CF Senior Member
8388's Avatar
Default Re: Oil Leaks From Exhaust Bolts? (ZR1)
When trying to remove a stud, I've always had some luck, by putting another nut in front of the existing nut and then turning the original nut in against the other nut in order to turn the stud rather than just the nut. Ofcourse the stud needs to be long enough for the second nut to fit. I hope this wasn't too confusing.
8388 is offline   Reply With Quote
Old 02-12-2002, 11:55 PM   #4
ZR1991
CF Senior Member
ZR1991's Avatar
Yes, when looking up when the car was on the rack today, I could see one stud, and it did seem to have enough threads for another nut. It is on the lower side of the flange, and I am assuming there is one on the other side or the engine as well. Do you think these are the only ones that are leaking?
As I remember the previous discussions, there is just one on each side. But it could be more than one... Anyone know?
Regards,
Old 02-13-2002, 12:05 AM   #5
skia
CF Senior Member
St. Jude Donor '09
skia's Avatar
I fi remember corectly there was 1 on each side. I had mine fixed under warranty (this was in 1991) after the fix they never leaked again. Good luck :cheers:
skia is offline   Reply With Quote
Reload this Page Oil Leaks From Exhaust Bolts?
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
Install from a local AZ shop (PICS) Y2K1 SS 5.0 THIS C5 Tech 13 11-07-2003 08:44 PM
Dented oil pan. How to swap? DaddyO C3 Tech/Performance 10 03-09-2003 10:13 PM
How to Install Head Bolts/Studs? VQT88Vette C4 Tech/Performance 14 12-18-2002 04:27 PM
DIY - DRM C5 Oil Cooler Install Dreamin Autocrossing & Roadracing 12 06-17-2002 09:11 AM
SYNTHETIC VS DYNO OIL REVISITED...OIL LEAKS?? OkeeGuy C3 Tech/Performance 13 06-02-2002 08:30 AM
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
