Corvette Forum
Go Back   Corvette Forum > C4 Corvettes, 1984 - 1996 > C4 ZR-1 Discussion
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
C4 ZR-1 Discussion General ZR-1 Corvette Discussion, LT5 Corvette Technical Info, Performance Upgrades, Suspension Setup for Street or Track
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 11-30-2008, 09:26 PM   #1
1cubano
CF Senior Member
Default Service-LTPWS
I have a 94 with service LTPWS that has stayed on for the last month.
The tire sensors were removed about a year ago, with no problems until now.
can anyone help to figure out how to fix it.
thanks,
angel
1cubano is offline   Reply With Quote
Old 11-30-2008, 09:49 PM   #2
Peter Mahr
CF Senior Member
Peter Mahr's Avatar
I think the only way to fix it is to remove the bulb in the Drivers Information Display. It isn't too hard. I am surprised that the system light did not come on right away when the sensors were removed.
Peter Mahr is offline   Reply With Quote
Old 11-30-2008, 10:33 PM   #3
Goldcylon
Goldcylon's Avatar
Remove the blub from the DIC. Since you removed the wheel sensors the light will always stay on until it either burns out or it is removed. Only MYs 90 and 91 will allow you to pull the wheels sensors with out the light coming on. Im amazed it didnt come on sooner unless you havent driven it much since removing the wheel sensors.
__________________
GOLDCYLON - 91 ZR-1 #2014
380 P&P&PCed,Ported Heads,Jeal Long tubes,/Corsas/FIKSE FM-5s /LED TLs, Hellas, F/R Baer Eradaspeed Rotors with CE/GS RED/BL calipers,CNCed Coolant Pipes,TPI Cvr,Filter cover,Stainless Bolts, DRM/DOM PROM STG V /ZFDOC mod build #102,DRLs,BMAD with stainless Debris Screen,Coplan Air Blaster, Pioneer AVIC Nav system,Brey-Krause HB,Sub Bar,DRM Coilovers
Goldcylon is offline   Reply With Quote
Old 12-01-2008, 09:29 PM   #4
1cubano
CF Senior Member
Quote:
thank for the info ,i will try to put the sensor back on , i need to get one more it was damage
one question i have a 91 zr1 in the garage next to the 94 would the 94 pick up the sonsor from the 91
thank angel
Old 12-01-2008, 09:38 PM   #5
ckulchar
CF Senior Member
ckulchar's Avatar
How difficult is it to get to the bulb?
ckulchar is offline   Reply With Quote
Old 12-01-2008, 10:22 PM   #6
old.hot.rodder
CF Senior Member
old.hot.rodder's Avatar
Default LTPWS Light ON
On my 93 I pulled the cruise control fuse. You will lose cruise but you will also lose the light. Hope this helps
old.hot.rodder is offline   Reply With Quote
Old 12-01-2008, 10:30 PM   #7
Peter Mahr
CF Senior Member
Peter Mahr's Avatar
To get to the bulb, you need to undo the shift plate around the shift lever. It has three screws. With it lifted, you can unscrew the leather shift boot and unplug the lighter and rear hatch release button. After that you remove the center air outlet grill and undo the three screws holding the radio trim plate. Pull the plate off and unplug the Full Power Switch wires. Finally you unscrew the Drivers Information Display and pull it out. The LTPWS warning light is on it's own wire and unplugs from the back.
Anyone planning to work on their car should get an official GM Service manual. I think Corvette Central and others has them.
Old 12-01-2008, 11:06 PM   #8
Goldcylon
Goldcylon's Avatar
thank angel
No Angel they wont work as they run on a different frequency. The 89-91 are the black bodied sensors for the LTPWS and the 92-96 are white bodied sensors. While they function the same and fit the same way on the tire band with the counterweight they are different. You can not mix and match. GC
__________________
Old 12-01-2008, 11:10 PM   #9
Goldcylon
Goldcylon's Avatar
Quote:
Peter answered this question pretty well the only thing I could add would be that two screws are underneath the console cover and the other screw is undeneath the cup holder. Slide it back to reveal the two lower screws for the radio surrround. Remove the top ac vent screws and the top mount for the radio surround is underneath. Pull at the center of the radio surround as two metal clips hold it into postion. The DIC is right above and just as Peter states. GC
__________________
Reload this Page Service-LTPWS
Tags
89, bulb, corvette, ltpws, remove, service
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
Need Help! Service LTPWS daz_96CE_greenwood C4 General Discussion 20 02-08-2003 09:01 PM
Service LTPWS....Are sensors still available????Tire place screwed up!!! Bartman C4 Tech/Performance 15 08-31-2002 10:54 AM
Service LTPWS thrills C4 Tech/Performance 22 01-23-2002 12:03 AM
Service LTPWS Warning PWRHSE2K C4 ZR-1 Discussion 14 11-07-2001 07:44 PM
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
