Corvette Forum
Go Back   Corvette Forum > C4 Corvettes, 1984 - 1996 > C4 ZR-1 Discussion
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
C4 ZR-1 Discussion General ZR-1 Corvette Discussion, LT5 Corvette Technical Info, Performance Upgrades, Suspension Setup for Street or Track
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 11-27-2008, 01:53 PM   #1
qwiketz
CF Senior Member
qwiketz's Avatar
Default ZR-1 fuel pump specs
hey, I did a quick search and I couldn't find the flow specs on the stock zr1 fuel pumps. Anyone know of a link to this info?
__________________
2004 Jaguar S type R. 4.2L V8 w/ Stiegemeier Snakebite Eaton M112 w/Alky Injection. H&R springs...
92 383, CNC'd LT4 top end, auto, custom vortech YSI trim, progressive alky kit, brembo 13.5's, magnesium speedline 18"'s with 275/335s, 7.30's@97 in the 1/8 (old combo)... The build up of an Low 10 second daily driver.
89 Saleen Clone with a 335" T trim'd blower motor. DFI, CNC'd victor jr's, vic 5.0. Was shooting for high 9's and 740 rwhp. Gone, but definately not forgotten...
qwiketz is offline   Reply With Quote
Old 11-28-2008, 02:52 PM   #2
Aurora40
CF Senior Member
Aurora40's Avatar
I found this from Delphi's website:
http://go.delphi.com/CS/DPSS/CATALOG...tNumber=FG0114
They say 16 g/s from the primary pump and 26 g/s from the secondary.
Aurora40 is offline   Reply With Quote
Old 11-28-2008, 05:13 PM   #3
qwiketz
CF Senior Member
qwiketz's Avatar
thanks!
Old 11-28-2008, 07:12 PM   #4
glass slipper
CF Senior Member
I thought both pumps were the same.
glass slipper is offline   Reply With Quote
Old 11-28-2008, 07:43 PM   #5
Aurora40
CF Senior Member
Aurora40's Avatar
I thought so too, but I dunno...
Old 11-28-2008, 08:33 PM   #6
WVZR-1
CF Senior Member
If you "rely" upon the Delphi information the service pump that most use specs out at 28 g/s (grams second)
There's 2 references for the ZR-1 pump in the specifications table:
Flow rate: 16 & 26
Minimum flow: 18.8 & 26.7
I'm with Bob "I dunno"! I've never seen the OE GM/AC Delco specifications listed.
WVZR-1 is offline   Reply With Quote
Old 12-03-2008, 03:14 AM   #7
qwiketz
CF Senior Member
qwiketz's Avatar
hey guys. Do these part numbers ring a bell or anything?
3287-1959
3099-1959
Pumps are silver with a red top. The numbers are etched into the metal of the pump.
Old 12-03-2008, 10:32 AM   #8
A26B
CF Senior Member
A26B's Avatar
Send a message via AIM to A26B
Off the cuff thought...... The secondary pump value may mean primary & secondary combined flow rate. The spec sheet doesn't actually say flow rate frome each pump individually. Seems reasonable , considering (1)the volume would most likely be rated at the single, outlet pipe for the assembly(actually stated as 7.9mm), (2) the secondary pump is only intended to run in conjunction with the primary under normal conditions and (3) it is a modular design, i.e. a single unit.
Additional support also comes in the form of the known, proven feasibility of replacing either or both of the stock OEM pumps with identical "Suburban" pumps.
Just a thought....
A26B is offline   Reply With Quote
Old 12-03-2008, 01:51 PM   #9
Aurora40
CF Senior Member
Aurora40's Avatar
I looked up the 454 Suburban (chose '99 as the year). The fuel pump for that is rated at 28 g/s:
http://go.delphi.com/CS/DPSS/CATALOG...tNumber=FG0091
I would think even if the 2ndary pump were higher flow, that you could still put it in place of the primary? I mean what would it hurt as long as the return line is big enough to return the excess.
I don't know much about fuel flow though. Jerry that could be the case that it's a combined rating. If 26g/s were the combined flow, is that enough for the 4-500hp that people run? Is there a calc/estimate for fuel flow vs horsepower?
Old 12-03-2008, 01:58 PM   #10
Aurora40
CF Senior Member
Aurora40's Avatar
Hmm, actually... So the injectors are rated at 22 lbs/hr by Delphi. that is ~2.77 g/s. So multiply that by 16 and you get a max fuel flow via the injectors of 44 g/s. I would tend to think then that the fuel pumps would be sized to deliver somewhere in that neighborhood. If the primary and secondary flow #'s were per pump that would be around 42 g/s, which maybe makes sense.
But I am no car designer and am still just guessing.
Old 12-03-2008, 03:00 PM   #11
A26B
CF Senior Member
A26B's Avatar
It gets fairly deep in just a quick look at calculating fuel requirements for a specific horsepower output. The calcs also include some variables and safety factors that need to be considered. I'm sure fuel pump delivery also has safety factors and variables such as pump efficiency that will certainly decline over time/use. Fuel pump output almost certainly is rated at the modular unit output and would not take into account pressure drop in the fuel line & fuel filter.
You can go to RC injectors website and obtain injector sizing requirements relative to power output, but there are still factors such a BSFC, duty cycle and fuel pressure at the rail.
Still, there certainly is some ambiguity in the way the pump output is stated by Delphi. Considerable good fortune would probably be required to actually get to talk to someone at Delphi who actually knew the answer for certain.
I agree completely.
Old 12-03-2008, 04:09 PM   #12
qwiketz
CF Senior Member
qwiketz's Avatar
guys, when you replace the pumps, are you going with the black things that come on there from the factory or just replacing them with stainless hose clamps? Also, are you replacing the hose at too while you have the sending unit out of the tank? The reason I ask is because the hose is shaped weird so coming up with a replacement isn't as easy as i would have thought.
Old 12-03-2008, 04:18 PM   #13
WVZR-1
CF Senior Member
Bob/Jerry
The "PUMP/SENDER" that you chose for a '99 IS NOT what is used for service pumps for a ZR-1. The # you chose is an assembly/module for use in a completely different "tank supply" system on a suburban. Take a look at the illustration of the part! I posted the specs of the "Delphi" pump for the correct service # in my earlier post. If you're using the Delphi "drop down" use 1996 2500 Suburban!! Actually the service pump has applications for "all" truck applications '96.
http://go.delphi.com/CS/DPSS/CATALOG...tNumber=FE0114
Old 12-03-2008, 06:51 PM   #14
Aurora40
CF Senior Member
Aurora40's Avatar
Quote:
Originally Posted by WVZR-1 View Post
Bob/Jerry
I was really just trying to find the flow #'s. The link you provided also says it flows 28 g/s. So perhaps that is about what the secondary pump on the ZR-1 flows. Or maybe it's way more but is the same size with the same connector, thus making it a workable replacement.
I guess if one were so inclined, it really wouldn't be super difficult to test, right? Put the output hose in something, supply voltage to one pump or the other for maybe 30 seconds and see how much liquid it pumps out?
I can't say I am so inclined...
Old 12-03-2008, 08:14 PM   #15
WVZR-1
CF Senior Member
I mentioned it primarily because someone sees the part # and then attempts to find an interchange or foolishly orders with no confirmation they'll be quite disappointed with it's cost and also the fact it's not a "service" pump but a "module" for nothing similar nor can it be disassembled to work. Then someone carries on about the "misinformation" of the Internet!
Delphi isn't OE! Delphi is an aftermarket supplier whose product was offered to many AC/Delco jobbers etc as a "competitive" product in the market place. They purchased, were given or whatever some tooling, excess stock, engineering prints etc (my thoughts) and the product line never took off. In the past 18 months or so some/most of the "older model" AC/Delco line has become "re-badged" maybe Delphi product and most is "off shore" origin!
GM / AC Delco never published engineering specifications, if you wanted to duplicate it you "bought it" and reverse engineered it! Is the Delphi published information the GM / AC Delco specifications? I don't know!!
In todays market place and you wanted a pump that performed you would buy it, test it then consider it's use. You might do this a few times! The box/brand isn't of significance "most times"!!
Old 12-03-2008, 09:32 PM   #16
A26B
CF Senior Member
A26B's Avatar
Quote:
Replace the black things with ss clamps & turn the screw out of the way for easier replacement of the module. I have re-used the hose.
Old 12-03-2008, 09:34 PM   #17
A26B
CF Senior Member
A26B's Avatar
Reload this Page ZR-1 fuel pump specs
Tags
84, corvette, delphi, fuel, interchange, pressure, pump, secondary, sending, spec, specs, system, unit, zr, zr1
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
Weights, measurements, ratios, strengths, etc leaftye C5 General 239 01-18-2012 04:29 PM
C4 Technical Summary and FAQ - Please Read on a Regular Basis. bogus C4 Tech/Performance 82 09-15-2011 12:07 PM
1990 C4 Track Car For Sale--H rocks h rocks Autocrossing & Roadracing 44 04-07-2006 06:07 PM
OK here is the lowest price I can ask.....$16,995 bigblock66vette C1s & C2s for Sale/Wanted 9 01-05-2002 06:51 PM
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
