C4 ZR-1 Discussion General ZR-1 Corvette Discussion, LT5 Corvette Technical Info, Performance Upgrades, Suspension Setup for Street or Track
My Bonneville Project up date
Old 06-21-2014, 08:25 AM
  #481
Daves obsession
Daves obsession's Avatar
Originally Posted by XLR8TIN
Be safe & Good Luck
The Jericho allows enough room to make this happen. 3.5 all the way:-)
Old 06-21-2014, 08:50 AM
  #482
rhanselman
rhanselman's Avatar
You may want to try one of my computers. Corey can set you up...
Old 06-21-2014, 01:02 PM
  #483
Daves obsession
Corey Say send Him one as soon as you can, we have to get the cars in the trailer and begin packing in 30-40 days.
This would be fantastic, we're running 8200-8500 rpm and the OEM runs in batch fire above 4400 rpm. And the thought of seeing data on the top end would be just the ticket. The density altitude is about 5500' in August.
please proceed with Corey Let me know what you can do.
Dave.
Oh I said Cars, yes R & D Landspeed Racing ( Rick and Dave) are taking two cars to the salt, for our Racing to Heal Fundraiser.
more data , and a picture of the other car to follow but for right now lets just say its a C4 and its wicked fast.
Oh and I would like to thank Jerrys Gaskets for their support in our efforts.
Old 06-21-2014, 02:40 PM
  #484
rhanselman
rhanselman's Avatar
I just sent the boy's at Mega Squirt an email requesting a unit right away. I'll let you know how quick we can turn one.
Cheers,
Ron
Old 06-21-2014, 05:59 PM
  #485
Tyler Townsley
Tyler Townsley's Avatar
The valve opening time above that makes sequential fuel useless. It eats processor time and gains nothing in the end. Go with the batch and use the extra processor time for on the fly fuel flow tied to wideband units on each side. Fastlane used a wideband on each cyl when he was racing his car and a Motec computer, Also used a Jerico.
Tyler
Old 06-21-2014, 06:57 PM
  #486
Daves obsession
Tyler
I am most interested in recording data above 5500. We're pretty much down to reading plugs with the stock computer. It's a 2.5 min wide open throttle application. Our gear ratios are close enough that we're always above 6000 rpm on shifts above 8300 rpm. It's one thing to make power down in the flat lands on the dyno. but on the salt the density altitude can range from 4400-8000 feet.
Old 09-18-2014, 05:53 PM
  #487
Daves obsession
Old 09-18-2014, 05:55 PM
  #488
Daves obsession
Thanks Jerrys Gaskets !!!
Old 09-18-2014, 10:39 PM
  #489
XLR8TIN
XLR8TIN's Avatar
Wow!
Old 09-19-2014, 12:51 AM
  #490
A26B
A26B's Avatar
Dave,
It is me who should be thanking you.... and I do thank you very much! I'm so proud of you guys and what you are doing for the ZR-1 Legend. Just let me know if there is anything I can do to help.
Jerry
Old 09-19-2014, 06:15 AM
  #491
Rkreigh
Rkreigh's Avatar
Originally Posted by A26B
Dave,
Jerry
car looks fantastic!
love to hear more about the megasquirt this is the perfect application and the WOT data logging and tuning is amazing
I'm interested in installing the megasquirt to control only the secondary injectors and also going to a coil on plug
I'll have to give corey and ron a call. the plug and play setup they have developed is amazing.
Old 09-19-2014, 07:51 AM
  #492
dclafleur
dclafleur's Avatar
That is so close. Is 230.545 still the current record? Either way that's incredible.
Old 09-19-2014, 10:26 AM
  #493
Daves obsession
This is from an earlier run with wet salt, after a rain. 229 mph. I rolled on to the throttle and short shifted 1 and second as traction was limited. if you watch the mountain at the edge of the window you will see how much the car moves around at the 3 mile. Change the setting to 720HD and you can read the GPS
Old 09-19-2014, 02:17 PM
  #494
XLR8TIN
XLR8TIN's Avatar
GOPR0022 - YouTube
Shifter sure looks slick, my interior looks just like that LOL, car seemed very straight, not much steering input
Old 09-19-2014, 03:56 PM
  #495
Daves obsession
its like driving on hard packed snow, but reaction times are too slow at those speeds if you to do much more than nudge it back toward the track, your going to spin as you will most likely set up the C4 shuffle, you know it , first one way then the next and then round and round you go :-)
Old 09-21-2014, 07:52 PM
  #496
5abivt
5abivt's Avatar
amazing stuff !!!! love it just love it ! That is scary at speed It looks like its floating !
Old 09-24-2014, 02:50 PM
  #497
ron_bidwell
ron_bidwell's Avatar
I am wondering how the Mega Squirt system worked as Corey is working on getting it installed in my 90 twin turbo Raptor project. I'm hoping it worked well for you.
Ron Bidwell
To My Bonneville Project up date
Old 09-24-2014, 02:59 PM
  #498
Vette Daddy
Vette Daddy's Avatar
Spectacular!!!
Old 09-25-2014, 01:02 PM
  #499
Daves obsession
Ron , we did not run the Mega Squirt, just Did not have the time to work it out before the runs.
I hope to try it with next years build, where we hope to equate $ in to HP.
Old 06-26-2015, 12:21 AM
  #500
Daves obsession
Ok its next year, and the motors about to go back on the dyno, with new profiled cams to make power up to 9500 rpm, ( we flattened off between 8000-8500 on the stock cams) also a bump in compression to over 15:1
Wish us luck and come see us at speedweek 2015 as the ZR1 is about to be King of the salt. all we need is 1/2 mile per hour improvement from last year to set a new record.
Dave
Quick Reply: My Bonneville Project up date
