C4 ZR-1 Discussion General ZR-1 Corvette Discussion, LT5 Corvette Technical Info, Performance Upgrades, Suspension Setup for Street or Track
Brake options
Old 07-10-2008, 05:42 PM
dbriana
dbriana's Avatar
Default Brake options
Now that I may be getting some 5 spokes, what are my options for brake upgrades, best bang for the buck and stay under $1000 for calipers, lines, drilled and slotted rotors, etc, whatever I need?
GS, C5, C6? Would anything fit with sawblades, if not I may sell to fund these. Polished with Vredesteins about 5k on them, anyone interested in the long term?
Old 07-10-2008, 07:32 PM
LT5corsa
1994 Admiral Blue ZZZZZR1
Support Corvetteforum!
LT5corsa's Avatar
Northeast Events Coordinator
I believe GS calipers will fit with Sawblades.....
You can do the upgrade for alot less than you expect. I spent under $700 for everything (rotors / calipers / ss lines / pads) Depending on if you want the calipers powdercoated (mine were).
Get a used set of C6 calipers($150, get JeffVettes adapters($100), ss lines ($100), pads ($120), rotors $250 depending and misc bolts needed ($50). That's aprox what you will spend!
GS upgrade would be much cheaper.... But the look of the C5 / C6 is much better and stronger brake too.
Old 07-10-2008, 07:57 PM
USAFPILOT
USAFPILOT's Avatar
Will C6 Z51 Brakes fit under the standard A-Mold on a 94, or do you need an 18" wheel...sorry to hijack.
Old 07-10-2008, 07:59 PM
dbriana
dbriana's Avatar
No problem, I would like to know to.
Old 07-10-2008, 08:02 PM
LT5corsa
LT5corsa's Avatar
C5 / C6 will fit and I believe C6 Z51 are identical in size too....
So yes, they will fit
Old 07-10-2008, 08:17 PM
FU
NCM Lifetime # 982
FU's Avatar
Location: HOME OF THE FREE. BECAUSE OF OUR BRAVE. Babylon NY
St. Jude Donor '06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-'18-'19-'20
The C5 brakes are a great upgrade. Find Jeffvette he may have an extra set of adapters. Some of the things that are needed are the C5 adapters, C5 calipers and rotors.
Old 07-11-2008, 11:57 PM
xlr8nflorida
xlr8nflorida's Avatar
I'd go with some Big Reds (PORSCHE)
Jeff can probably hook you up. Your rotors and other goodies would have to come later though because your budget would be blown on these calipers.
Old 07-12-2008, 01:59 AM
lite blue
lite blue's Avatar
St. Jude Donor '12
Porsche calipers on a Vette?
My car would spit those out like an Autolite spark plug!
Old 07-12-2008, 09:09 AM
xlr8nflorida
Sure, just powder coat them over the porsche logo and your Vette won't know. Good bang for the buck $$ and they are Brembos.
JeffVette has them on his ZR-1 - look and perform great.
Old 07-12-2008, 11:55 AM
Bluewasp
Bluewasp's Avatar
NoVa Events Coordinator
St. Jude Donor '14
MOVIT makes a kit that will fit behind the sawblade rims using brembo big red calipers... www.movitusa.com www.movit.de
Old 07-13-2008, 02:27 PM
Sgreg
Sgreg's Avatar
Thought they were 14 inch rotors on C6 ?? Might be thinking of C-6/Z06. 14 inch won't fit.
Old 07-16-2008, 11:54 PM
USAFPILOT
USAFPILOT's Avatar
Here is a new one...how much modification would be required to get those new Carbon Ceramic Brakes brakes of the new ZR1 on a 94. Assuming I had all the money I needed. Which I'm sure I dont presently.
To Brake options
Quick Reply: Brake options
