Name that chip
Name that chip
Am hoping someone might be familiar with a chip that was made for my 92.
It looks like this. Under the 2 windows or openings on the chip there is a white sticker in 1 window you can read 92 and Lt-5
S2 In the other window.
This is defiantly a aftermarket chip as the Cages 1-4 shift is gone and the fans come on at 190 or something. I dont know if anything else is on there.
My 92 runs well, before I get the Marc H chip was wonder what the ^%$# this is?
Gotta pic, that should clean up the mystery?
Chip description
I don't have a good camera.
I pulled the chip out and took off the blue cover exposing the internal circuits. There are 2 small white stickers that show thru the top 1 says 92 lt5 S2 and the other says ZR1. these are written in pen. Looks like there was a sticker on the outside between the windows that fell off.
I dont think this will help, but the 1-4 shift was eliminated and the fans come on at 190 and im pretty sure the full power is always on.
The thing is sometimes the engine dosent return to idle well reason im thinking about the Marc h chip, Thanks for reading!
Anyone seen this chip. I contacted the dealership guy said it may have been dyno tuned.
Well, if you want to send me the chip, I can read it and see if it matches some of the other ones I have on file. The return to idle would be no indication of Marc's chip. Most tuners play with WOT and leave Part Throttle alone especially if its mail order.
My ZR is a 92 and had a Marc Randolph calibration in it although not anymore.
I can vouch for DOM hes a great guy and a chip burner in his own right. If your concerned. Chip reading is his hobby. And getting to 400HP to the RWs is his passion.
You might find the answer in this thread as some with aftermarket chips discuss the markings and characteristics.
http://zr1netregistry.com/forum/showthread.php?t=852
