Corvette Forum
Go Back   Corvette Forum > C4 Corvettes, 1984 - 1996 > C4 ZR-1 Discussion
Register Forgot Password?
Register Vendors Buy a Vette Albums Search Today's Posts Mark Forums Read FAQ TSB & RecallsGarage
Search
C4 ZR-1 Discussion General ZR-1 Corvette Discussion, LT5 Corvette Technical Info, Performance Upgrades, Suspension Setup for Street or Track
Welcome to Corvetteforum.com!
Welcome to Corvetteforum.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Corvetteforum.com today!
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 04-11-2008, 02:10 PM   #1
terryszr1
CF Senior Member
Default left o2 lean, what do i look for?????/
i cant find my fsm(due to moving) did a scan and found let o2 lean . what do i look for as to what the problem could be , thanx for any help
terryszr1 is offline   Reply With Quote
Old 04-11-2008, 03:40 PM   #2
Goldcylon
Goldcylon's Avatar
Bad injector(s) would be my guess without my FSM infront of me
Goldcylon is offline   Reply With Quote
Old 04-11-2008, 04:27 PM   #3
LowFlight
CF Senior Member
St. Jude Donor '03
Senior Member
Cruise-In V Veteran
LowFlight's Avatar
Location: Humble Pilot In The Service Of The Drax Corporation
lowflight
I had the same problem on my 91 and it was injectors if I recall
LowFlight is online now   Reply With Quote
Old 04-11-2008, 05:05 PM   #4
terryszr1
CF Senior Member
ok, i kinda thought that would be the case , but wasnt very sure off the top of my head. what kind of injectors should i replace them with .i have found 3 , rc which i used for my black car but way pricy accels or those new guys who have a whole set for around 360?
Old 04-11-2008, 05:32 PM   #5
kabnvtt
CF Senior Member
kabnvtt's Avatar
What promted you to scan it? Were you having any issues?
kabnvtt is offline   Reply With Quote
Old 04-11-2008, 09:53 PM   #6
terryszr1
CF Senior Member
the reason i scanned it , i was kinda gettin on it for a friend and i just didnt feel like the power was there . plus since getting that scann tool i hook it up when on the highway just to ck stuff out . the left side blk learns are 120-123 right 132-137 if that helps . those are when going on flat ground @70-75
Old 04-12-2008, 12:35 AM   #7
kabnvtt
CF Senior Member
kabnvtt's Avatar
Thanks, I have been fighting a low idle miss and think it may be injectors so I was just curious. What type of scan tool are you using?
Old 04-12-2008, 01:29 AM   #8
terryszr1
CF Senior Member
I am using an auto xray4000
Old 04-14-2008, 09:29 PM   #9
BennieC.
CF Senior Member
BennieC.'s Avatar
Have you checked the O2s. You should check it first by commanding it lean and see how low the voltage goes down to and command it rich as well to see how high the o2 voltage goes up to. Check response time as well. You might have bad o2 sensor.
__________________
Bennie Cabacungan
Street & Track Performance
by Auto Start
9882 Waterman Rd. Suite 140
Elk Grove, CA 95624
916-714-2886
www.autostartsmog.com
BennieC. is offline   Reply With Quote
Reload this Page left o2 lean, what do i look for?????/
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
Hotcam 1320dance C4 Tech/Performance 56 08-11-2005 11:57 PM
Headers & chip ?? Mylzi C4 ZR-1 Discussion 28 07-24-2005 03:17 PM
tech help wanted PUREC4 C4 Tech/Performance 10 01-23-2004 02:50 PM
I still have my low rpm stumble..... phrogs C4 ZR-1 Discussion 24 09-06-2003 11:32 AM
I think I found my hesitation problem-but I need advise on what to do! bhamvett C4 ZR-1 Discussion 19 07-17-2003 09:53 AM
I'm getting a lot of detonation...can someone help? los7883 C5 Tech 68 06-18-2003 11:20 PM
Powered by vBulletin® Version 3.8.7
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.2
Emails & Password Backup
