Corvette Forum
Go Back   Corvette Forum > C4 Corvettes, 1984 - 1996 > C4 ZR-1 Discussion
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
C4 ZR-1 Discussion General ZR-1 Corvette Discussion, LT5 Corvette Technical Info, Performance Upgrades, Suspension Setup for Street or Track
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 03-12-2008, 03:59 AM   #1
Z51JEFF
CF Senior Member
Z51JEFF's Avatar
Location: Fremont Ca. I will do No business with ANY company that boycotts Arizona.
Send a message via AIM to Z51JEFF
Default 86 wheel in a 91?
Will an 86 steering wheel bolt up to the steering column in my 91?Ive got an N.O.S 86 wheel and ,well Ive never been a big fan of G.M.s early airbag systems.Id really like to bolt this 86 wheel in my car.I could have asked this over in general but I figure,I bug you guys enough why stop now
Z51JEFF is offline   Reply With Quote
Old 03-12-2008, 10:18 AM   #2
-=Jeff=-
CF Senior Member
-=Jeff=-'s Avatar
Quote:
Bolt up, YES it should 'Bolt up'
my concern would be the back side trim and depth, of the trim on the 89 is as deep as the 91 wheel it should work fine.
-=Jeff=- is offline   Reply With Quote
Old 03-12-2008, 01:16 PM   #3
zr1fred
CF Senior Member
No, I don't believe it will work, the 89 down uses a tilt column. You might try J&D Corvettes, I believe he might have a direct replacement. Otherwise it might be easier to just change the whole column.
zr1fred is offline   Reply With Quote
Old 03-12-2008, 04:35 PM   #4
WVZR-1
CF Senior Member
Quote:
I believe you meant "telescopic"!
I don't believe you can change the entire column because the mast jacket support is in a different location. I had one of each (an '87 and a '90) side by side and I seem to recall noting that. I've sold the early to a fellow that's local and if he's not done the install I could maybe check again.
To use the early wheel on the later it would take quite a combination of parts to adapt the horn mechanicals, and the canceling cam to make it all function. I believe with patience, two columns plus access to several other combinations of cams etc you might be able to accomplish it. It might test your "talents"!!
NOW! Why would you even consider this? As "picky" as you seem to be and "profess" to be, I just don't understand. Sell the '86 NOS and buy a "fresh wrap" for the car! If the bag scares you just disable it! That's a simple chore.
WVZR-1 is offline   Reply With Quote
Old 03-12-2008, 06:08 PM   #5
zr1fred
CF Senior Member
Yes I did. (I need "think" check)
Old 03-12-2008, 07:54 PM   #6
Z51JEFF
CF Senior Member
Z51JEFF's Avatar
I dont want to change the column.Other than repainting the side trim,which I should have finished in a few weeks,ive pretty much fixed all the blemishes in the car.The steering wheel in the cars got some deep scratches in it and I cant find a new one,I like this 86 wheel alot better than the 91 wheel.
Old 03-12-2008, 08:07 PM   #7
Z51JEFF
CF Senior Member
Z51JEFF's Avatar
Quote:
As far as picky goes,If I dont like something Ill change it If its a simple enough job.I would never do anything to this car to diminish its value,unbolt this,put it in a box and forget it.Ive got an 84 that this wheel was intended for but that cars in hibernation so I wont be selling this wheel.As far as a rewrap goes I would consider this IF I could get my wheel back.Chances of that happening are pretty slim.The only thing that would kill this idea is the depth between the two wheel and the canceling cam swap.Testing my talents has already been pressed to the limits with the CDM removal awhile back.Somebody mentioned a guy that restores these 91 wheels for NCRS,sound familiar?...............On a side note when I put my feelres out there looking for an N.O.S steering wheel for this car I got a call from somebody that had one complete.................$3,000.
Reload this Page 86 wheel in a 91?
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
C4 Technical Summary and FAQ - Please Read on a Regular Basis. bogus C4 Tech/Performance 82 09-15-2011 12:07 PM
86 11 Sec Project Vette datobin1 C4s for Sale/Wanted 10 07-01-2005 03:50 PM
Launching a Z06 for drag racing oderja C5 Z06 Discussion 14 03-19-2003 11:19 PM
Weighed my 91 ZR-1 92 ZR1 C4 ZR-1 Discussion 24 03-08-2003 06:49 PM
Budget wheel bearings at Mid-America... BlackRocket C4 Tech/Performance 14 06-04-2002 02:44 PM
89 Corvette Owners!! Torqued84 C4 Tech/Performance 28 11-24-2001 12:22 PM
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
