Corvette Forum
Go Back   Corvette Forum > C4 Corvettes, 1984 - 1996 > C4 ZR-1 Discussion
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
C4 ZR-1 Discussion General ZR-1 Corvette Discussion, LT5 Corvette Technical Info, Performance Upgrades, Suspension Setup for Street or Track
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 03-11-2008, 12:04 AM   #1
nickzvette
CF Senior Member
Default for an emergency repair.
Is the primary and secondary fuelpump the same can they be switched if one goes out...Also can an electric fuelpump be set up outside the tank for a side of the road repair.... I'll try anything to keep from leaveing my baby on the side of the road...Z Vette
nickzvette is offline   Reply With Quote
Old 03-11-2008, 12:08 AM   #2
lgaff
CF Senior Member
lgaff's Avatar
Fuel pump swap is easy can be done anywhere, I did one at the track, you simly need to remove the rubber boot, unlug the pump, unbolt the filler neck, pull out and swap.....very easy. 20-30 minute job, just make sure to replace the clamps, and don't reuse the factory, they can leak or blow off easily.
Yes, they are both the same, without both car runs like S**T!
LGAFF
92 ZR1
#234
lgaff is offline   Reply With Quote
Old 03-11-2008, 02:11 AM   #3
Goldcylon
Goldcylon's Avatar
Quote:
Identical and yes they can be swapped.Not sure about the electric fuel pump
Goldcylon is offline   Reply With Quote
Old 03-11-2008, 11:48 AM   #4
Blown67427
CF Senior Member
Blown67427's Avatar
It's also important not to drive around on low fuel alot, as this tends to overheat the pumps, and cause premature failure.
Blown67427 is offline   Reply With Quote
Old 03-11-2008, 12:35 PM   #5
glass slipper
CF Senior Member
I had the same thing happen to me on a trip and no fuel pumps were available. I had another 400 miles to go so I bought a few tools and swapped the secondary/primary fuel pumps on the side of the road in about an hour and completed my trip with no problems. (Just don't turn full power on since you don't have both fuel pumps.)
Or you can run a jumper wire from the cigarette lighter to the secondary fuel pump and bypass the secondary fuel pump relay to make the secondary pump run all the time. There's a light green wire running through the cargo compartment (under the carpet/trim) that goes to the secondary fuel pump with a connector in the right hand rear of the cargo compartment that you can plug in to. You'll need to take the 15 amp fuse from the cigarette lighter and replace it with the 10 amp fuse from the "fuel pump 2" slot for proper protection. Don't use the fuse from "fuel pump 1" because the ECM monitors the voltage in the fuel pump circuit off that fuse. You'll have to pull the plug from the cigarette lighter when you stop the engine (since it always has 12V) and put it back in before starting. The jumper is a "cleaner/quicker" way of getting back on the road versus the "swap on the side of the road" method above...they accomplish the same thing though. Build the jumper and find the green wire before you go on your trip and all you'll have to do is plug and play.
glass slipper is offline   Reply With Quote
Old 03-11-2008, 01:18 PM   #6
ZO6R1
CF Senior Member
ZO6R1's Avatar
ZO6R1 is offline   Reply With Quote
Old 03-12-2008, 01:10 AM   #7
nickzvette
CF Senior Member
Default I cant believe all this great information..
Quote:
Originally Posted by ZO6R1 View Post
thank you. For about 2 months now Ive been writeing down all the info. Ive been reading on this site their is so much I learned I cant wait to break down. I'll just take my tools,wire,ducttape,glue,string,a pocket knife and head out on the road.....Kidding aside Thank everyone who sends all this information Iam going to start writeing down names also and when I meet you guys at any gatherings maby I can buy lunch I feel obglated THANKYOU THANKYOU ...............Z Vette
Reload this Page for an emergency repair.
Tags
fuel, pump, relay, secondary, zr1
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
For Sale: 2002 QS ZO6; Houston, TX hallwd C5 Corvettes for Sale 21 05-28-2003 10:54 PM
Wanted- Tire inflation kit for Z06 Acorn-Glen C5 Parts for Sale/Wanted 17 02-10-2003 10:10 PM
Nail Repair For Run Flat Tires phrankw C5 Tech 24 11-27-2002 07:57 PM
Please explain "Bubba" to an ignorant German Sir Tripower C3 Tech/Performance 22 09-26-2001 01:22 AM
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
