Corvette Forum
Go Back   Corvette Forum > C4 Corvettes, 1984 - 1996 > C4 ZR-1 Discussion
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
C4 ZR-1 Discussion General ZR-1 Corvette Discussion, LT5 Corvette Technical Info, Performance Upgrades, Suspension Setup for Street or Track
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 03-09-2008, 01:33 PM   #1
Dominic Sorresso
CF Senior Member
Dominic Sorresso's Avatar
Send a message via AIM to Dominic Sorresso
Default WB 02 hook-up
If you have installed a WB O2 in your ZR, I'd be interested in knowing where you made the connections. Once I amm done with plenum and head port matching, I'll need to re-do WOT fueling I am sure. I'll be using a Zeitronix ZT-2. With the display I'll be showing MAP, AFR, and TPS. Would like to know:
1. where you have grounded sensor?
2. connected switched power?
3. Todd told me there is a tachometer takeoff by the master cylinder
4. If your WB is permanently installed, which way did you route
cabling thru to cabin?
__________________
92 Black Rose/Black ZR-1 #458
92 Aqua/Grey ZR-1 #474 SOLD
84 Xfire Z51SOLD
Dominic Sorresso is offline   Reply With Quote
Reload this Page WB 02 hook-up
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
lookie...latest dyno jerkyboy C4 Tech/Performance 12 08-25-2005 09:37 AM
DFI help on VE tables vs timing vs inj DC jerkyboy C4 Scan & Tune 16 08-20-2005 09:56 AM
I am trying to contact Geoff Jeal.. Mylzi C4 ZR-1 Discussion 107 12-07-2004 06:48 PM
EGT to tune air/fuel ratio? SuperL98 C4 Scan & Tune 34 05-23-2002 08:03 PM
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
