Quote:
Originally Posted by Z51JEFF
Other than the nipple,is the breather the same?I got one from the dealer and its got the nipple on the left side.How about the air cleaner housing?
The housings are the same other then the nipple yes. The actual cover came in 3 different configurations. 1st one is plain with venting on the front, 1 has a cover that draws air from the top and 1 has a plastic cover that draws air from the sides. I am only aware of the steel cover that draws air from the top and the plain cover with vents being used on ZR-1s.
