Water pump question
Well, I went out this afternoon to back it out of the garage to put new a new tag for this year on and noticed a few more drops on the garage floor. I opened the hood and right in front of the largest pulley on the bottom center of the engine on the Black cross frame it is wet with what looks like coolant. So, I guess it is the damn water pump. Right?
Get a telescopic mirror, and take a look at the weep hole on the water pump. If the drops are coming out of there, then yes the water pump needs replacement. Keep in mind that when the fan comes on, the fuild could wind up just about anywhere, as the air flow will spread it around.
Appreciate all the advice
Got a reman pump and no core exchange. Will install it this week.
Am 98% sure that it's the pump but if not then I have a nice spare.
Will let you know. Thanx again
