C4 ZR-1 Discussion General ZR-1 Corvette Discussion, LT5 Corvette Technical Info, Performance Upgrades, Suspension Setup for Street or Track
Z06 / Zr1
Old 01-06-2008, 04:37 AM
pieces_r6
pieces_r6's Avatar
Default Z06 / Zr1
I thought the ZR1 would be killed but if you compare these 2 videos it's not that bad:
z06 - 30=>120 mph - 11 seconds
http://www.youtube.com/watch?v=I6EiNFiLhV0
zr1 - 30=>120 mph - 12 seconds
http://www.youtube.com/watch?v=2prRg1z-a64
Not bad!
Ok, you have speedo errors, gear changes which have some impact on the time, etc... but it's a good indication of the performances of the old zr1!
Old 01-06-2008, 10:02 AM
4cefed
4cefed's Avatar
The C6 Z06 is much faster than a stock ZR-1. You can try and slice it anyway you want but line the two up and the ZR-1 will be looking at taillights very quickly (375 or 405 version, doesn't matter).
Another subject; how does the Z06 go to 190 so smoothly? It that video taken on a dyno or something? I've gone 180 many times and there is no way that video camera could be held without any vibration at all.
Old 01-06-2008, 10:18 AM
Aurora40
Aurora40's Avatar
Those mile runs out in Las Vegas, didn't they seem to show that over a larger speed range that the C6 Z didn't really stomp all over the LT5? Or am I mistaken? I didn't go to any, just read, but seem to recall stock Z06's were around 160mph at the mile point, and 350 LT5's were hitting low 150's?
Old 01-06-2008, 02:24 PM
shaynezrl
shaynezrl's Avatar
well our cars are mostly driven in the street but in the racing world 10mph difference is an eternity. you will be a first loser at the finish line. Our cars needs more hp to hang with the c6 z06.
shayne
Old 01-06-2008, 02:41 PM
locobob
locobob's Avatar
At the Vegas mile event stock ZR-1's were around 150mph, stock C6Z low to mid 160's. To outrun a stock C6Z in the mile you need at least a fully ported 350cid with all the bells and whistles - Dempseys example pulled off a 168mph run. A rolling start race is advantagous to the ZR-1 as the C6Z does a much better job getting off the line.
Old 01-06-2008, 04:19 PM
Greybeard ZR1
Greybeard ZR1's Avatar
[QUOTE=4cefed; Another subject; how does the Z06 go to 190 so smoothly? It that video taken on a dyno or something? I've gone 180 many times and there is no way that video camera could be held without any vibration at all.[/QUOTE]
I'm pretty sure it's on a camera mount. If you listen again, you can hear the wind buffeting at speed.
It's possible to fake this, (re-mix the sound), but I'm convinced this is real.
BTW, it's a much better way to do it, rather than have your scared sh*tless passenger try to keep a steady shot at 150+mph.
To Z06 / Zr1
Quick Reply: Z06 / Zr1
