C4 ZR-1 Discussion General ZR-1 Corvette Discussion, LT5 Corvette Technical Info, Performance Upgrades, Suspension Setup for Street or Track
What's the rear-end gear ratio on ZR-1s?
Old 11-25-2001, 09:22 PM
Wadoka
Wadoka's Avatar
St. Jude Donor '03-'04
Cruise-In 1-2-3-4-5 Veteran
Default What's the rear-end gear ratio on ZR-1s?
What 's the gear ratio in the rear end of a ZR-1?
Wondering because the cars were so strong for top-speed mph...
~Matt
Old 11-25-2001, 10:12 PM
DoctorV8
Support Corvetteforum!
DoctorV8's Avatar
Default Re: What's the rear-end gear ratio on ZR-1s? (Matt Black)
3.42:1. Fifth (0.75:1) is the top speed gear.
[Modified by DoctorV8, 8:13 PM 11/25/2001]
Old 11-25-2001, 10:29 PM
SPEEDEMON
SPEEDEMON's Avatar
The gear ratio for the ZR-1's is 3.45.
Old 11-25-2001, 10:42 PM
ZR-1DUDE
ZR-1DUDE's Avatar
Most of them are 3.45.
Some are 3.55s. I beleive after 1991 all were 3.45 unless it was an export model - then it was 3.55. 3.55s are rare regardless.
D.
:seeya
[Modified by ZR-1DUDE, 11:47 PM 11/25/2001]
Old 11-25-2001, 11:48 PM
Ryan Bell
Ryan Bell's Avatar
Cruise-In III Veteran
Cruise-In IV Veteran
Default Re: What's the rear-end gear ratio on ZR-1s? (SPEEDEMON)
Exactly.....I've always heard 3.45 was the ratio.
Old 11-26-2001, 11:20 AM
gmanZR1
gmanZR1's Avatar
I am really thinking hard about changing the gearing in my car. What is the best gear to change to, and what kind of rpm are we looking at when cruising on the highway in 5th and 6th gear, at 60 and 70 mph??
I am not too concerned about gas mileage (my computer says I average around 16 any, mostly around town driving with a heavy foot!), just wondering.
Old 11-26-2001, 02:37 PM
BUD D'DONATO
BUD D'DONATO's Avatar
Default Re: What's the rear-end gear ratio on ZR-1s? (gmanZR1)
430 are sooo much fun :yesnod: :yesnod: :yesnod: :yesnod:
Old 11-26-2001, 03:13 PM
Rainy99
Rainy99's Avatar
Default Re: What's the rear-end gear ratio on ZR-1s? (BUD D'DONATO)
I have a Canadian export 91, would that mean i have the 3.55s? Is there a code that would tell me this or?? Just a thought...
Brennan
Old 11-26-2001, 03:24 PM
USAZR1
USAZR1's Avatar
Received 1,870 Likes on 1,085 Posts
Default Re: What's the rear-end gear ratio on ZR-1s? (Rainy88)
Some of the ZR-1's used in early testing were equipped with a 3.54 ratio but supposedly all production cars came with a 3.45 gear. If Hib sees this,maybe he can offer his insight.
It's always amazing to me how many people do not realize the meaning of 6th gear's 50% overdrive. They still think a 4.10,4.30,or even a 4.56 gear will put the revs outta sight on the highway. Nothing's further than the truth. Here is the approximate rpm your ZR-1 will be spinning in 6th gear at 70mph:
3.45 gear: 1,700rpm
4.10 gear: 1,950rpm
4.30 gear: 2,100rpm
4.56 gear: 2,200rpm
Old 11-26-2001, 03:37 PM
DoctorV8
DoctorV8's Avatar
Default Re: What's the rear-end gear ratio on ZR-1s? (USAZR1)
Sorry for the earlier mis-type. Here is some info off the ZR1-net:
"3:54 Rear Ends
The following information provided by Gordon Killebrew.
It was originally released for cars going to the European market because of low noise level requirements.
It was not an option you could order. It was automatically a 3.54 axle instead of a 3.45 when going to a Country that required this.
From the start of production in 1988 (MY89) to 01/01/89, all 6-speeds had a 3.54 axle. After 01/01/89 the ZR-1s used a 3.45 axle. The L98 6-speeds used a 3.31 axle. The 3.54 axle was not EPA certified in 90-92 because it went to the European area market. In 1990 the L98 & LT5 6-speeds used a 3.45 except the GHO code with a 8.5 ring gear.
The are no records for how many, and there were no break points. They were produced as ordered.
I doubt that any went to the country of Switzerland due to their noise level requirements. Most ZR1's did not meet their requirements. There were some sent to England."
Personally, I like cruising at 90 mph with 2000 rpm on the tach, and I like being able to hit nearly 60 mph in 1st gear....so I'm sticking with 3.45's, and just plan to add more power!
Sanjay
Old 11-28-2001, 08:51 PM
phrogs
phrogs's Avatar
Default Re: What's the rear-end gear ratio on ZR-1s? (DoctorV8)
I have the 3:45's :cheers:
Old 11-30-2001, 12:26 PM
Stan A
Stan A's Avatar
Default Re: What's the rear-end gear ratio on ZR-1s? (phrogs)
Food for thought!!!
The Callaway Supernatural Tw-Turbo uses 3.91:1.
Reeve figured out out this was the best gear for the power this car makes for the street driver and highway straight line runs. Not the best for the dragstrip.
Stan A :chevy
Old 12-02-2001, 05:06 PM
Hib Halverson
Pro Mechanic
Pro Mechanic
Hib Halverson's Avatar
Received 1,143 Likes on 597 Posts
Default Re: What's the rear-end gear ratio on ZR-1s? (ZR-1DUDE)
All production ZR-1 have 3.45:1 axle ratios. Also transmission ratios are 0.75:1 for fith and 0.50:1 for sixth. A few of the 89 ZR1prototypes and pilots had 3.54:1 axles but no 89 was ever sold and most were crushed.
Old 12-02-2001, 08:02 PM
phrogs
phrogs's Avatar
Default Re: What's the rear-end gear ratio on ZR-1s? (Hib Halverson)
:cry That sucks but I love the stories of individuals finding them and restoring those cars that were supposed to be destroyed :yesnod:
To What's the rear-end gear ratio on ZR-1s?
Quick Reply: What's the rear-end gear ratio on ZR-1s?
