Corvette Forum
Go Back   Corvette Forum > C4 Corvettes, 1984 - 1996 > C4 ZR-1 Discussion
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
C4 ZR-1 Discussion General ZR-1 Corvette Discussion, LT5 Corvette Technical Info, Performance Upgrades, Suspension Setup for Street or Track
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 11-09-2007, 09:28 PM   #1
drd21968
CF Senior Member
drd21968's Avatar
Default my z and nagging problems
just got my zr1 out of the shop a few days ago .shop repaired vacum leak under plenum ,new plugs,wires,new starter since some times it would not start.had a problem when i first picked it up but they corrected it and the car ran great, better than it ever has.take it out tonight and no start,gave two teen agers 5 bucks to push start me.well at least i thaugt its running right when it start chugging in 6th gear at about eighty on interstate.the no start has got to be the start enable relay,am i right.but the chugging and even a little backfire once, i really dont know. my wife has a new c6 and im taking a beating from her over my z .she has been with me twice of the four no starts.i have got to get it fixed before she catches me out and wants to race.she has done it before,ten years ago she smoked my 86 vett with a ls1 camaro,it forced me to buy a 96 lt4.
drd21968 is offline   Reply With Quote
Old 11-09-2007, 10:07 PM   #2
Jeffvette
CF Senior Member
Jeffvette's Avatar
Location: No more yankee my wankee, the Donger is tired!
Quote:
Originally Posted by don donahue View Post
Just got my zr1 out of the shop a few days ago. The shop repaired vacum leak under plenum ,new plugs,wires,new starter since some times it would not start. Had a problem when I first picked it up but they corrected it and the car ran great, better than it ever has. Take it out tonight and no start,gave two teen agers 5 bucks to push start me, well at least I thaught it was running right when it start chugging in 6th gear at about eighty on interstate. The no start has got to be the starter enable relay, am I right? But the chugging and even a little backfire once, I really dont know.
The lack of smoothness in 6th gear will probably be a injector issue. But it could be something as simple as spark going away in a cylinder. But yes, the no start condition is probably the relay. It's up underneath the dash. Easy access.
Quote:
My wife has a new c6 and im taking a beating from her over my z. She has been with me twice of the four no starts. I have got to get it fixed before she catches me out and wants to race. She has done it before, ten years ago she smoked my 86 vett with a ls1 camaro, it forced me to buy a 96 lt4.
Quuite giving your wife the newer rides. Besides, shouldn't she be in a minivan :
Jeffvette is offline   Reply With Quote
Old 11-09-2007, 10:07 PM   #3
_twisted_
CF Senior Member
_twisted_'s Avatar
sounds like your a candidate for the relay trick that was mentioned in the other thread this week.
_twisted_ is offline   Reply With Quote
Old 11-09-2007, 10:37 PM   #4
drd21968
CF Senior Member
drd21968's Avatar
thanks jeff i know you have a lot of experience with these cars.i put plugs in this car 3 months ago and when it was in shop they changed plugs and said a few were loose and a couple looked hair line cracked at the base.are there seating issues with these plugs i dont know about? thanks i have the relay, installing it tom. she hates mini vans but she has a suv for a kid hauler
Old 11-09-2007, 11:28 PM   #5
lgaff
CF Senior Member
lgaff's Avatar
What is your fuel pressure at the rail?
LGAFF
92 ZR1
#234
lgaff is offline   Reply With Quote
Old 11-10-2007, 12:36 AM   #6
Goldcylon
Goldcylon's Avatar
Quote:
Sadly this maybe true it was for me
Goldcylon is offline   Reply With Quote
Old 11-10-2007, 01:43 AM   #7
drd21968
CF Senior Member
drd21968's Avatar
how do you test them, car is not throwing a code or engine light.are primaries and secondaries the same.are they just standard 21 lb injectors? only 30k on my clock is it common to fail this soon . i hope thats not it ,if it is what are some injector options and prices? i like my car but it has been expensive lately .but i want to get it right i plan to keep it thanks for the help
Old 11-10-2007, 02:22 AM   #8
Jeffvette
CF Senior Member
Jeffvette's Avatar
how do you test them,9
DVM
And not showing a code does not mean somthing is not wrong.
They are the same flow rate. But the clips are different. You need to cut the tabs off of the primary injector
Doesn't matter the mileage. Letting them sit is worse.
Stock - Around 1,000 (good guy price)
RC's - Around 960.00
Accel 150121 - 600.00
It's worth it when everything is clicking.
Old 11-10-2007, 09:31 AM   #9
drd21968
CF Senior Member
drd21968's Avatar
thanks,i have a good fluke meter, but if i am there i may as well just change them .arent the 90 and 91 injectors faulty ,isnt it better to upgrade?
Old 11-10-2007, 11:00 AM   #10
turbo-max
CF Senior Member
turbo-max's Avatar
Send a message via AIM to turbo-max
aren't upgrades "always" better?
turbo-max is offline   Reply With Quote
Reload this Page my z and nagging problems
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
