Corvette Forum
Go Back   Corvette Forum > C4 Corvettes, 1984 - 1996 > C4 ZR-1 Discussion
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
C4 ZR-1 Discussion General ZR-1 Corvette Discussion, LT5 Corvette Technical Info, Performance Upgrades, Suspension Setup for Street or Track
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 02-13-2007, 02:13 PM   #1
FlaVert
CF Senior Member
Support Corvetteforum!
FlaVert's Avatar
Default Parking Brake Problem
The parking brake on my 94 Z won't engage. I pull the handle up, there's plenty of pressure, like the brake is engaging, I don't hear any ratcheting and the handle never "catches". When I let it back down, it has the reverse amount of pressure, like the brake is dis-engaging. The brake light also illuminates on the dash while pulling up and turns off on the way down.
Am I doing something wrong, or do I have a problem? Just thought I'd ask here first before I pull the seat out and get all into it.
Thanks,
Rick L.
FlaVert is offline   Reply With Quote
Old 02-13-2007, 02:43 PM   #2
YorkL8apex
CF Senior Member
YorkL8apex's Avatar
I am assuming you are pulling up with the release button NOT engaged and returning the handle to the floor with the button NOT engaged.
If so you should feel engagement pulling up and it should "free wheel" as you move the handle out of the way by pushing it back to the floor.
To disengage just pull up with the button NOT engaged until you feel pressure, then Press the button while pulling up just a bit, hold the button and return the handle to the floor and you're all set to rip it to7000RPM
If you depress the buton on the way up and down it will disengage the brake. Sounds like that might be what you are doing.
YorkL8apex is offline   Reply With Quote
Old 02-13-2007, 03:07 PM   #3
We Gone
CF Senior Member
We Gone's Avatar
Or if your operating it correctly... crud gets stuck around the ratcheting mechanism along with Old Grease they tend to stick…Pull the seat and take the cover off and clean it up.
We Gone is offline   Reply With Quote
Reload this Page Parking Brake Problem
Tags
brake, c4, corvette, parking
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
How Many of you Have Suffered Parking Brake Failure? cgh1 C5 Tech 78 06-09-2010 03:29 PM
Parking Brake problem? z28plus C5 Tech 26 01-27-2004 01:24 AM
Proper procedure for adjusting parking brake??? Wheelman C4 Tech/Performance 12 10-04-2003 03:12 AM
Guess who gets to check their parking brake out tonight when they get home.. GlockLT4 C4 Tech/Performance 19 11-07-2002 09:56 PM
SS parking brake shoes GTR1999 C3 Tech/Performance 22 02-14-2002 03:03 PM
Does your parking brake work? Koz C3 Tech/Performance 47 11-16-2001 03:52 PM
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
