You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Corvetteforum.com today!
But a Jack-A-Vette works well under the rear as well. If using a floor jack go under the frame just in front of the rear tires and you'll see two vertical frame rails. Place the jack pad centered under one side and lift. Then replace inboard of the jack pad with a jack stand. Repeat for other side. Be sure to set the parking brake, put in a low gear and chock the front tires. Finally give it a good shake prior to going underneath. If it falls down at least no one is underneath it!
find the spots on the sides ner the riangles that are on the rocker panel.
then just get under there and make sure you are jacking on the frame lip that is under the car, not on the fiber glass.
I have jacked up many a C4 over the years and never had a problem at all with leaving the car completely buttoned up hood closed doors cloesd and hatch closed I usually get them up pretty high on the jackstands lift one side up first then the other pretty simple really
__________________
Johnny P
SSGT 4 LIFE 1994-2009 USMC Now in the first civ div!
1990 ZR-1 #845
1968 427/400hp
1982 Ferrari 308 GTBi
LT5 Registry #694,NCRS MEMBER,NCM Lifetime Member # 913
Gone but not forgotten 87 blk Cp 89 red Vert 1990 ZR-1 RIP 1991 ZR-1 RIP 69 427/435 coupe 02 EB Z06 90 ZR-1 #354 90 ZR-1 #1908
Quote:
Originally Posted by Blown67427
As oppose to screwing up the door hinges, the lock mechanism and the door jams.
Mmmmm hm. How many documented cases of lock mechanisms and door jams damaged from jacking up the car with the doors closed can you show us.
__________________
90 ZR-1 # 2043, Red/Saddle, K+N filter, B+B Triflo Exhaust with X-pipe, 5 spoke Chrome wheels, 415 cid by LPE, 4 piston Alcon/Baer calipers with 13.5 inch rotors,PF pads, stainless braided brake lines, Ron Davis rad, brand new water pump, Coplon duct, stainless works headers, ZR51 C beam plates, random technology cats - Now removeable , supercar tires in stock sizes, Hurst Shifter, HID headlights, HUD, A.O. Engineering Forced Air Intake, Relocated MAT sensor ------------------------------------------------- 532 RWHP, 507 RWTQ - 648 hp at the crank!!!!!!!!!!!!
I would want everything as structurally stable and intact as possible, which would mean doors closed, top on! I wouldn't hesitate to open doors after it is level, and top on though.
The doors are not a structural part of the car. The fact that it has hinges on one end and a latch on the other may appear to some of you as a structural part of the car, but it's not. When you use a floor jack, on any corner, as oppose to using it under your Dana 44, you end up slightly twisting the chasis. With the doors close, all your doing is putting stress on the hinges and on the latch. I've studied the structural design of the C4, and understand it quite well. Now, if some of you find this silly, please continue doing it in the way that makes you happiest.
__________________
We can't judge the future, but the future will judge us. :flag
