Corvette Forum
Go Back   Corvette Forum > C4 Corvettes, 1984 - 1996 > C4 ZR-1 Discussion
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
C4 ZR-1 Discussion General ZR-1 Corvette Discussion, LT5 Corvette Technical Info, Performance Upgrades, Suspension Setup for Street or Track
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 11-20-2006, 05:05 AM   #1
BlackRocket
CF Senior Member
BlackRocket's Avatar
Default Fidanza flywheel questions....
Dot the Fidanza flywheels need balancing? Also, what clutch package is recommended with these?
Thanks!
BlackRocket is offline   Reply With Quote
Old 11-20-2006, 08:42 AM   #2
Usa1-Zr1
CF Senior Member
Usa1-Zr1's Avatar
No they dont need balanced good to go out of the box. What clutch to used will depend on you HP / torq numbers and driving style .If you make 400 at the wheels or so the stock will be just fine ,This will start a big thread hang on...
Usa1-Zr1 is offline   Reply With Quote
Old 11-20-2006, 10:41 AM   #3
90 Corvette ZR-1
CF Senior Member
90 Corvette ZR-1's Avatar
Send a message via AIM to 90 Corvette ZR-1
just run the stock clutch, you'll be fine with anything short of a TT ZR-1
90 Corvette ZR-1 is offline   Reply With Quote
Old 11-20-2006, 01:38 PM   #4
Zr1 Destroyer
CF Senior Member
Zr1 Destroyer's Avatar
Location: Thornton,Co. Press 1 to Proceed in English or 2 for Deportation ...don't let the fence hit you in the azz!
Quote:
The Fidanza/stock clutch works well on the street, but I had no luck with the Fidanza and a stock clutch at the track, went about five rounds(5-10 minute breaks in between) and the clutch just got too hot and started slipping pretty bad.....I changed to a sprung hub disc shortly after and never had an issue since!
I had Doug Rippie re-flash my chip to idle @ 900rpm's to get rid of the low rpm/idle rattle that the Fidanza is famous for....works great!!!
Zr1 Destroyer is offline   Reply With Quote
Old 11-20-2006, 01:48 PM   #5
Zr1 Destroyer
CF Senior Member
The only two TT's that i have ever seen RUN at the TRACK are both running an auto trans.....i wonder how well a TT using the 6 speed would hold up after a couple runs?
Old 11-20-2006, 02:45 PM   #6
1990 QUASAR BLUE
CF Senior Member
1990 QUASAR BLUE's Avatar
This is going to be part of my winter project. Did the sprung hub help reduce some of the noise? Also, did it take 900 rpm's to finally quiet it down or do you think that you could have gotten away with a little less?
TIA
Mike
1990 QUASAR BLUE is offline   Reply With Quote
Old 11-20-2006, 03:21 PM   #7
Zr1 Destroyer
CF Senior Member
Quote:
TIA
Mike
The noise was about the same using the sprung hub, i then tried some thicker trans fluid ...very little change there as well! Between 1000rpm and 900rpm was the magic number from Doug R. when i talked with him(not sure if you could go lower), but the 900rpm setting got rid of the noise all together! If your car is still together try strting it up and let it get warm and see if it goes away at maybe 800rpm......it sounds funny but that's how I decided to go with the 900rpm set in the chip.
Good luck
Old 11-20-2006, 09:51 PM   #8
1990 QUASAR BLUE
CF Senior Member
Reload this Page Fidanza flywheel questions....
Tags
1990, corvette, fidanza, flywheel, zr1
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
questions bout my new clutch and flywheel Impala Balko C4 Tech/Performance 17 08-14-2005 09:51 AM
Balancing Dual Mass Flywheel and single mass flywheel questions 89vette C4 Tech/Performance 11 04-06-2004 03:55 PM
Light-weight flywheel questions 91mongoose C4 ZR-1 Discussion 16 01-15-2002 10:58 PM
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
