Corvette Forum
Go Back   Corvette Forum > C4 Corvettes, 1984 - 1996 > C4 ZR-1 Discussion
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
C4 ZR-1 Discussion General ZR-1 Corvette Discussion, LT5 Corvette Technical Info, Performance Upgrades, Suspension Setup for Street or Track
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 11-19-2006, 11:08 PM   #1
phrogs
CF Senior Member
phrogs's Avatar
Default Best way to clean the cylinderheads
Ok these babies are full of carbon I would usually take them to the machine shop and have them cleaned there but im not so sure about that since
1) I dont have new intake vavle guide seals
2) dont have the proper tools to remove the secondary butterflys
so if I had them cleaned wouldnt this damage the vavle guide seals and the small bearing for the butterflys?
I want to get it nice and clean before I put it all back together.
I can wire brush the combustion chamber but what about the intake bores they have years of acumulation of carbon which I just dont get I beat on this car alot and let them secondaries open up alot!
phrogs is offline   Reply With Quote
Old 11-20-2006, 05:13 PM   #2
lbs90ZR
CF Senior Member
lbs90ZR's Avatar
I cleaned mine with kerosene and a spray gun first. Used carburater cleaner from wal mart for the carbon and avoided all the seals with that(might feel a little goofy after spraying a few cans of that around though) . It disolved the carbon right down to aluminun with enough spraying and mine was pretty dirty in the secondary runners, Only thing I used steel brush on was vavles and then lapped them in, wouldn't reccomend steel brush on aluminum, hog bristle brush would work good but didn't have one if yours is really stubborn.
I'm deactivating butterflys so didn't worry too much about them.
Did you find a valve removal tool?
lbs90ZR is offline   Reply With Quote
Old 11-20-2006, 05:22 PM   #3
Jeffvette
CF Senior Member
Jeffvette's Avatar
Location: No more yankee my wankee, the Donger is tired!
John, go to the GM dealer and ask for their heavy duty top end cleaner. It will need to sit on the head for a bit, but it will clean evertyhing off. I believe they sell it in a spray as well as a pure liquid as well.
Jeffvette is offline   Reply With Quote
Old 11-20-2006, 06:16 PM   #4
phrogs
CF Senior Member
phrogs's Avatar
Quote:
Jeff Is this stuff cool for the heads as well?
I have all the valves removed now and I want to clean the ports on the head of all the nasty carbon thats in there.
Im going to get that stuff for the pistons I guess its not going to hurt the rest of the motor so ill have at it.
Old 11-20-2006, 06:21 PM   #5
phrogs
CF Senior Member
phrogs's Avatar
Im keeping the system in here because im going to be trading this car and the next guy wants a stock ZR1
As for the tool I used a piece of PVC pipe from the home depot cost me .28 cents
Reload this Page Best way to clean the cylinderheads
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
