cranked right up !
no service lights
smoked a lil bit ...
ran lil rough...
few seconds it smoothed right out...
then
serp belt flapping like crazy...shut her down...changed the position of the idler into the other notch (yea i found another one down there
cranked her up runnning smooth beauuuuitful to me anyway
watching pressures & temp , all of sudden Service Engine Soon light came on
waited til oil temp got up and took her for a drive around the block,
SES went out and hadn't came back on. rechecked everything i could remember tonite and found i didn't put the gas cap back on when i took it off to work on injectors....you think the SES picked that up
let it run lil longer to check for leaks and such...
everything seems okay.
New: RC 210's, water pump, starter, alternator, complete vacuum line set, delco wires, delco plugs, water temp sensors, sec solenoid, sec accuators, accel coils packs, complete coolant hose set, stat, serp. belt, idler pulley, pvc's, as Joey would say "Gettin a scracth"
PRICELESS
I want to thank all for helping me out
it wasn't as bad a i thought it would be, worst part was getting my a$$ kicked by a couple factory hose clamps popping off and nailing me, one lost kinda bent way out of shape oops
anger management kicked in though
Feeling Good that's all........til morning
Luis
