C4 ZR-1 Discussion General ZR-1 Corvette Discussion, LT5 Corvette Technical Info, Performance Upgrades, Suspension Setup for Street or Track
Ignition advance
Old 08-19-2006, 08:08 AM
jabrun
jabrun's Avatar
Default Ignition advance
Does anybody know how much extra timing aftermarket chips usually have built into them? A DRM chip to be specific.
Old 08-19-2006, 10:16 AM
tpepmeie
tpepmeie's Avatar
Generally, from 1-4 degrees, depending on load. Here are the entire spark advance changes from a DRM off the shelf cal. There aren't many.
Code:
SA#1 (SPT OPEN)
3600 RPM	90kpa	+1.1
		95	+1.1
		100	+1.1
4000 RPM	85kpa	+2.1
		90	+2.1
		95	+3.2
		100	+4.2
SA#2 (SPT OPEN)
4000 RPM	85kpa	+2.1
		90	+2.1
		95	+3.2
		100	+4.2
4500 RPM	85kpa	+2.1
		90	+2.1
		95	+3.2
		100	+3.2
5000 RPM	85kpa	+1.1
		90	+1.1
		95	+2.1
		100	+2.1
5500-7000	all kpa	+2.8	28.2d total
Todd
Old 08-19-2006, 07:26 PM
jabrun
jabrun's Avatar
Thank you.
To Ignition advance
Quick Reply: Ignition advance
