Anyone tried this place for injectors?
This guy is selling brand new Bosch injectors that have all been bench tested and guaranteed to be within 1% flow-matched along with a 3yr warranty.
http://www.fiveomotorsport.com/Injec...TPI.asp#zr1pri
I emailed him and he said these injectors are both the 225cc injectors.
His price on the primaries are $329.50
His price on the secondaries are $289.50
Comes out to about $620
This is close to the Accel deal that Mike (Bad ZR1) found and gives another option over the RC injectors.
Are Bosch injectors any good?
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15-'16-'19, '21-'22-'23-'24
Trey,
This is just an observation from reading the C4 Tech & performance section....a large number of those guys over there seem to prefer those injectors on the larger cube modified motors in their C4's.
Tom
Tom
When I had my Stock Multec injectors and had some bad ones, I bought injectors from him. They worked great. Kept getting bad injectors pop up (none of his though) so I made a swap to RCs. Very nice guy. He runs the business out of his garage, or at least did at that time.
Guest
Posts: n/a
Sounds like another affordable option. I would be curious what the bosch injectors for the "early" applications look like and what was the original application. Maybe he is willing to provide a picture? I'm not aware of any Bosch injector that would work without the larger O-ring on early cars, but it would be very intersting if there is such a beast. If he does, send it my way.
The only thing I would look into is the 225cc rating. There have been a few posts that others have not had good results with 225's on stock and mild mod engines. Experts like Haibeck will likely talk you out of 225's unless you run a big cube motor with the corresponding calibration.
