Corvette Forum
Go Back   Corvette Forum > C4 Corvettes, 1984 - 1996 > C4 ZR-1 Discussion
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
C4 ZR-1 Discussion General ZR-1 Corvette Discussion, LT5 Corvette Technical Info, Performance Upgrades, Suspension Setup for Street or Track
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 06-17-2006, 11:23 PM   #1
phrogs
CF Senior Member
phrogs's Avatar
Default First crank and she lives!
Ok got the motor all back together on the DRM500 hooked up all the oil coolant everything is set cranked it over and it came to life on the first try I had a big grin om my face
Only thing is the lifters are quite loud right now, I had removed the fuses for the injectors and cranked it over a little while to get the oil moving around is there something I missed or do I just need to throw a larger oil in there Im using 10W30 for this initial run??
any sugestions
phrogs is offline   Reply With Quote
Old 06-17-2006, 11:34 PM   #2
mercruiser
CF Senior Member
mercruiser's Avatar
How long did you let it run?
mercruiser is offline   Reply With Quote
Old 06-17-2006, 11:58 PM   #3
LoTu5
CF Senior Member
LoTu5's Avatar
Nice one phrogs,mine was a bit noisey when i first started it,then i checked the coolant and found i needed to add more (There was air in the system) ,then once the coolant had got around the engine she went nice and quiet.
LoTu5 is offline   Reply With Quote
Old 06-18-2006, 12:05 AM   #4
phrogs
CF Senior Member
phrogs's Avatar
Quote:
not long maybe 2 minutes
I just want to make sure I got my ducks in a row before I let it run longer
Old 06-18-2006, 03:18 AM   #5
dallas916
CF Senior Member
dallas916's Avatar
Some of that noise may have been the cam tensioners, but if your oil level is good and you have good pressure you might just need a little more time for everything to pump up. Idle speed only.
dallas916 is offline   Reply With Quote
Old 06-18-2006, 04:22 PM   #6
Jeffvette
CF Senior Member
Jeffvette's Avatar
Location: No more yankee my wankee, the Donger is tired!
Congrats John.
Jeffvette is offline   Reply With Quote
Old 06-18-2006, 11:44 PM   #7
phrogs
CF Senior Member
phrogs's Avatar
Well got the motor all set to run today, got it running and was adding coolant to burp it and noticed a coulple of leaks had to readjust some hoses then fired it up again let it run for quite a while and all the clicking is gone the lifters got pumped up and im happy with a big grin!
Ill get some pics up later just been hella busy!
Time to keep on kicking got a couple of codes one being the 23 the other 45 23 is valid since I have it disconected and im a bit stumped on 45 maybe it needs to get on the road and bang through the gears
Old 06-19-2006, 12:14 AM   #8
FastZR1
CF Senior Member
FastZR1's Avatar
JP,
Sounds like it needs a test run down some of those back roads out there. Run it like it was meant to be run!
Ed
FastZR1 is offline   Reply With Quote
Old 06-19-2006, 12:25 AM   #9
jonszr1
CF Senior Member
congrats. Sure ccool whe n all that hard work pays off . If I may ask who built your motor ? or did you just have the machine work done/? Reason I ask is my car has 154000mi . ANY HELP you could provide as to how to go about getting this project started . I am new and alot of people I've talked to just scratch their head when I mention this motor.
jonszr1 is offline   Reply With Quote
Old 06-19-2006, 09:47 AM   #10
Cdn Z06 Mike
CF Senior Member
Cdn Z06 Mike's Avatar
Send a message via MSN to Cdn Z06 Mike
Congrats Johhny! looing forward to seeing you rip the gears at BG next year!
Cdn Z06 Mike is offline   Reply With Quote
Old 06-19-2006, 10:55 AM   #11
kmoudy
CF Senior Member
kmoudy's Avatar
cool tools..Johnny...you da man of de moment...gotta have a big smile on your face...hope all is going well "4" you...
stay safe...Keith
kmoudy is offline   Reply With Quote
Old 06-19-2006, 12:48 PM   #12
phrogs
CF Senior Member
phrogs's Avatar
Quote:
The work on this motor was done already before I bought it, but the work was don by doug rippie motorsports its a DRM 500 package
http://www.dougrippie.com/
I tore the motor apart to powedercoat and change all the gaskets, retime the cams and just make sure everything was in order I didnt rebuild it but you need to cantact some of the big guys that were mentioned in your other thread ess mark hiebeck theres a few people who can work on them but im not sure were to get some parts, I have another engine I need to rebuild and it seems the main bearings are hard to find....
Reload this Page First crank and she lives!
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
Hello Greetings From Georgia bence13_33 C3 General 11 04-19-2005 12:14 PM
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
