Corvette Forum
Go Back   Corvette Forum > C4 Corvettes, 1984 - 1996 > C4 ZR-1 Discussion
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
C4 ZR-1 Discussion General ZR-1 Corvette Discussion, LT5 Corvette Technical Info, Performance Upgrades, Suspension Setup for Street or Track
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 06-15-2006, 03:43 PM   #1
knightsm
Junior Member
St. Jude Donor '05
knightsm's Avatar
Default Vibrations -Not the good kind!
Hey all you grease monkeys help/advice needed. Recently change the rear gears to 4.10's, set the backlash at the lower permissable setting, .oo4", it turned sweetly. Now with 650 miles on the clock, ( a change at 500), there is bad vibration above 90mph which gets worse the faster we go. The rear is filled with Penziol and GM additive. Although I'm sure I replaced the prop shaft in the position it was originally I keep toying with the idea of spinning it 180. Anything else I should try? The rear seems to be working correctly no noises whines etc, the only whine is from her indoors as it's technically her toy! Help!!
knightsm is offline   Reply With Quote
Old 06-15-2006, 04:01 PM   #2
Crabs
CF Senior Member
Crabs's Avatar
It sounds like a balance issue of some kind. Have you had the rear tires balanced lately?
Failing that, I'd take a good hard look at the U-Joints and Drive Shaft. Could you have knocked any balance weights off of the drive shaft when you did the rear end?
I can't imagine that's a gear or rear end problem, I'd start with the easy/cheap things first.
Good luck!
TomC
'90ZR1 #792
Crabs is online now   Reply With Quote
Old 06-15-2006, 04:29 PM   #3
FU
NCM Lifetime # 982
St. Jude Donor '06-'07-'08-'09-'10-'11
Support Corvetteforum!
FU's Avatar
Location: Big government & Blue States stink. BABYLON NY
LTPWS sensors fall apart ?
FU is offline   Reply With Quote
Old 06-15-2006, 05:54 PM   #4
Crabs
CF Senior Member
Crabs's Avatar
Quote:
Ahh yes...
Can't forget those.
Have you made any high speed runs lately?
The wheel sensors are known to fail at high speeds.
Good luck!
TomC
'90ZR1 #792
Old 06-16-2006, 05:00 AM   #5
knightsm
Junior Member
St. Jude Donor '05
knightsm's Avatar
Default Cheers
Thanks for the response , unless you are chronic insomniacs by the time you read this I will have put her,(the Z not Louise ), over a pit and checked out the whole drive area. I will re-post with a positive response soon I hope.
Old 06-18-2006, 06:02 PM   #6
knightsm
Junior Member
St. Jude Donor '05
knightsm's Avatar
Default Latest vibration news
Progress in the right direction, spun the prop shaft 180, after noticing there are marks on both sides of the U-Joint yoke, thanks GM/whoever! Much better, however still a slight buzz which wasn't present on the car before. I replaced the old U joint bolts on one side for new ones but when they arrived at my local parts store from the good old US they were the same thread rate but a larger head(not 5/16ths) and longer. I cut them down and installed two on one side and as the other side was ok just replaced the old ones. You know what I'm thinking now, even though the weight difference is very slight, one side of the U J is heavier than the other and something at the back of my mind from school many years ago tells me the faster the drive shaft spins the weight difference will be magnified, hence the inbalance. What 'cha think? It's over the pit again for a bolt weighing session, if I can't get the correct ones before next weekend I will machine the replacements so all weigh the same.
Old 07-06-2006, 08:42 AM   #7
LoTu5
CF Senior Member
LoTu5's Avatar
Mark,how did things go with the vibration?it was good to get aquainted at the Nats with you and your lady.
LoTu5 is offline   Reply With Quote
Old 07-08-2006, 10:38 AM   #8
Rob 93ZR-1
CF Senior Member
Cruise-In IV Veteran
Cruise-In VII Veteran
Rob 93ZR-1's Avatar
Location: Fear causes hesitaiton...and hesitation will cause your worst fears to come true. Houston TX
Any progress on this issue. I think I may be in the same boat.
Rob 93ZR-1 is offline   Reply With Quote
Old 07-08-2006, 03:36 PM   #9
Bigvmaxx
CF Senior Member
Bigvmaxx's Avatar
I am having the same issue also... however... as you mention about U joint bolt lenth and weight. IMHO it hardly matters when the bolts in question are so close to the centerline of rotation. Especially if all 4 bolts are the same lenth.
How much to long are the bolts ?
How much difference in weight between these bolts ?
It seems the amount of weight in question is so minimal that it would be hard to get a vibration from it.
You have me wondering now... maybe I better order some new bolts because I have been swapping bolts around. Also a good time to check everything and make sure it is tight to spec.
Could spline wear in the spindle cause this problem ?
Let us know if you find out anything...
Bigvmaxx is offline   Reply With Quote
Reload this Page Vibrations -Not the good kind!
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
Experiences with Centerforce Clutches? sjaroslo Engine Mods 19 10-06-2004 01:52 AM
balancer alignment LT1 mitchcole C4 Tech/Performance 11 09-27-2004 02:08 PM
NJ pants on fire ZR1Pete C4 ZR-1 Discussion 128 09-16-2004 09:31 PM
Dash Buzz JimAgain C5 Z06 Discussion 9 09-09-2003 04:46 PM
U Joint install - H E L P 427390 C1 & C2 Corvettes 36 12-06-2002 08:35 AM
What kind of rear speakers are you using? MagikDraggin C4 General Discussion 15 08-01-2002 08:19 PM
Bad bad bad Vibrations da da da da TheOman C1 & C2 Corvettes 33 03-27-2002 10:46 PM
Stock Shifter?? (Long) TRZ06 C5 Z06 Discussion 9 07-27-2001 07:37 PM
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
