Corvette Forum
Go Back   Corvette Forum > C4 Corvettes, 1984 - 1996 > C4 ZR-1 Discussion
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
C4 ZR-1 Discussion General ZR-1 Corvette Discussion, LT5 Corvette Technical Info, Performance Upgrades, Suspension Setup for Street or Track
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 06-13-2006, 03:27 PM   #1
ZLEGEND
CF Member
ZLEGEND's Avatar
Send a message via ICQ to ZLEGEND Send a message via AIM to ZLEGEND Send a message via Skype™ to ZLEGEND
Default need help for small hydraulic fluid leak
I've got a small clutch fluid lead, got under the car & tighted 4 bolts that connect to clutch, thats where it seems to be leaking ( still leaking). Could it just need the gasket ? Sure need some help & where can I get clutch parts. Car only has 10m on miles. From the master cy down all"s fine. Appreciate the help & enterainment from the threads.
ZLEGEND is offline   Reply With Quote
Old 06-14-2006, 09:02 AM   #2
tomtom72
CF Senior Member
Support Corvetteforum!
tomtom72's Avatar
Default clutch fluid leak
I'm not following your Q, sorry to be so dense!
The slave is held on by two nuts so what four bolts are you talking about? Did you tighten the bolts that hold the transmission to the bell housing, are those the bolts you're talking about?
Is the fluid coming out of the inspection plate on the bell housing? If yes, it could be from the slave or it could be from the rear main seal on the crank. Is the bottom side of the slave wet? Are you having to add fluid to the reservior on the clutch master frequently?
I would suggest a web site that may be of assistance: ZR51Performance.com is a great source of info. on the zf/6spd and the hydrulic clutch system.
Tom
tomtom72 is offline   Reply With Quote
Old 06-16-2006, 09:34 AM   #3
ZLEGEND
CF Member
ZLEGEND's Avatar
Thx tomtom72, I have to add fluid once every couple years, very small leak, it seems to be coming from the bottom of slave. I'll check the web site you suggested. I need to see a diagram of the whole unit & I,m gonna have to get it up on a rack, can't do squat with it jacked up trying to crawl around under neath. Can you suggest a good place to buy parts if needed, appreciate help. zlegend
Old 06-17-2006, 08:47 AM   #4
tomtom72
CF Senior Member
tomtom72's Avatar
Sorry this took so long...my p/c caught some spyware/trojan thing & I didn't want to do anything till I got the situation straightened out.
Anyway parts can be had at any chevy dealer or I use rockauto.com. They are quick! Partsamerica.com I heard is quick also....the hyd parts are not cheap, figure if you have all the OE stuff in there it's time to do it all....hose, clutch master & slave. The hose on 90's is nla, replaced by the 91 hose. The 90 slave is superceeded by a 91 & up slave but the stuff is all the same, 90 bleeder is in a different spot. I used wagner for the master and used raybestos for the slave and got the hose from chevy.
One thing on these parts is way bad Q/Control from the mfg. The slaves have the piston seal installed backwards and I got some metal debris in the ones I bought & also some have found the bores to be pre-scored. Beware that you will have to take the stuff apart to check those issues....unless that stuff has been straightened out by now.
again, sorry for the delay!
Tom
Old 06-17-2006, 09:03 AM   #5
ZLEGEND
CF Member
ZLEGEND's Avatar
Thx again for help tomtom72,no worry for delay, I'm just going to pull everything out & start from there. Gm built this un believable car then stuck that mickey mouse s&%t in there. As I said it,s a 10m mile car, I take my wife out to dinner with it now & then, do a half dozen car shows wait around for someone who wants to challenge the zlegend. Had to take a c5 z06 last week , the youngster was quick out of the gate but the LT5 ran him down, guess he won't be doin those stupid dry revs anymore. appreciate zlegend
Old 06-17-2006, 09:22 AM   #6
tomtom72
CF Senior Member
tomtom72's Avatar
Thanks for understanding....I'm not too good with p/c software stuff!
If you have any Q's just post up....the first chevy dealer I called about a slave replacement for my 90 said there were none, they were NLA. I had to go over to the netreg site to get the guy the part number & explain what & why....he didn't believe me till he looked up a 91 slave!
The hyd parts are all the same so no worries. The hose I'm not sure is ava in the aftermarket...but the 91 & up hose is s/s braided, my OE hose was rubber & it had some soft spots. The hose was expensive, I think like $125.00.
Tom
Oh forgot this....get the GM fluid, not brake fluid(DOT3) or the master will squeek!
Reload this Page need help for small hydraulic fluid leak
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
Corvette Parts News! New C6 Section! 8/28/04 CorvettePartsBob Ken's Newsletters 9 10-05-2004 12:23 PM
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
