C4 ZR-1 Discussion General ZR-1 Corvette Discussion, LT5 Corvette Technical Info, Performance Upgrades, Suspension Setup for Street or Track
BBC In A 85
Old 05-15-2006, 09:24 PM
michael allman
4th Gear
michael allman's Avatar
Default BBC In A 85
had a 69 zl1 one of two ,wanting to put a BBC into a 85 the 69 would spin the tires at 120 going from third to fourth gear
Old 05-16-2006, 11:56 PM
petefias
petefias's Avatar
Interesting. Was that a coupe or a convertible? I know the owner of one He owned that since new. When did you sell yours?
BBC installation into a C4 has been done. Not a bolt in, but doable. If you want a torque monster just put in gears into a ZR1, you will like it. I think the ZR1 will outshine the BBC easily, especially over 150. In a 69 120 feels fast.
Old 05-17-2006, 10:47 AM
michael allman
4th Gear
Default zl1
sold it about 20 years ago .the whole car was not like a plain corvette ,two tops ,green painted red the motor is still in n.c. we raced ss for the factory back then .still have two cracked blocks. the front end was turned up just a little bit in the front ,dual clutches,americam mags no chrome under the side pipes,vents and no back cutouts ,different brakes ,different springs , at 55 mph 1300 rpm
3000 95 mph still have pictures of the car also have a 63 electric 6 foot corvette that was given to us when we were racing by gm. made by barry toy craft not many made . my dad was in nascar but i raced in a st. line
Old 05-17-2006, 10:54 AM
TONYDEE64
TONYDEE64's Avatar
You've obviously never ridden in a C4 big block vette......
Old 05-17-2006, 12:50 PM
DDSLT5
DDSLT5's Avatar
Not all of them have that little snail attached to the front!
Old 05-17-2006, 03:50 PM
TONYDEE64
TONYDEE64's Avatar
Ya, but that's just for looks... I don't even have an impeller in mine...it's just for the chicks!!! They LOVE the shiney stuff!!
Old 05-17-2006, 04:07 PM
ZR WON
ZR WON's Avatar
Dwight:
You typed:
<<<Not all of them have that little snail attached to the front!>>>
I'd put a certain LPE 540 convertible that we both know up against most 415s *without* the spray.. With spray, that 540 will walk over any ZR-1 sans the TTs and Fastlanes old car...
Brian A.
90 ZR-1
12.09@118
01 Z06
not stock
Old 05-18-2006, 12:45 AM
DDSLT5
DDSLT5's Avatar
Originally Posted by ZR WON
Dwight:
You typed:
Brian A.
90 ZR-1
12.09@118
01 Z06
not stock
Brian - I'll take my chances - bottom line, you still gotta put the power to the ground. Spinning tires don't win races! Ask Tony how easy it is to get the power to the ground. 550-600 rwhp is the limit for street tires to actually hook 3rd/4th gear.
Now - beyond that - if a 540 cid BB couldn't whop a 415, if traction wasn't limited, it would be some POS big block methinks!
There is no replacement for displacement!
Old 05-18-2006, 01:27 AM
michael allman
4th Gear
Default motors coming out
the 350 will be a pile of junk in a day or two , what intake to use with a bbc and what windshield wiper motor. it's a shame they put the rack in the way where a 871 does not fit. the wife said not to go through the hood with the blower . all the info would help a lot
Old 05-19-2006, 09:19 AM
TONYDEE64
TONYDEE64's Avatar
Brian - Ask Tony how easy it is to get the power to the ground. 550-600 rwhp is the limit for street tires to actually hook 3rd/4th gear.
It isn't easy .. but it sure is fun trying... It's a lot like your TT C5 I would imagine. I can pretty much break the rear tires loose at will in any gear at any speed (remember I also have a 3:73 gears which doesn't help) but I assure you the car still moves forward at an extreme rapid rate in the process..
To BBC In A 85
Quick Reply: BBC In A 85
