Corvette Forum
Go Back   Corvette Forum > C4 Corvettes, 1984 - 1996 > C4 ZR-1 Discussion
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
C4 ZR-1 Discussion General ZR-1 Corvette Discussion, LT5 Corvette Technical Info, Performance Upgrades, Suspension Setup for Street or Track
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 03-08-2006, 01:26 PM   #1
Shrek
CF Senior Member
Shrek's Avatar
Default Secondaries???
Our low mile 91 garage-hog has an awesome seat of the pants feel when the secondaries kick in. Our high mile 91 track-rat runs great but has no feeling that they're coming on. Like I said it runs great and we have no problem holding our own with the other ZR-1's and Z06's.
My question-- Is there a simple way of determining whether or not they are working properly other that scanning or dynoing it? Or is there something secondary related I can disconnect without throwing a code that will cause it to be a slug and verify that the secondaries are working?
EDIT both are bone stock other than a Haibeck chip for fan control and key on in the racer.
__________________
Shrek
Shrek is offline   Reply With Quote
Old 03-08-2006, 02:10 PM   #2
JoeyGibson
CF Senior Member
JoeyGibson's Avatar
Try a burnout, if you can't get a smoking burnout, the secondaries are not working
JoeyGibson is offline   Reply With Quote
Old 03-08-2006, 02:14 PM   #3
DDSLT5
CF Senior Member
DDSLT5's Avatar
Power key! Turn it off, you'll feel the difference!
DDSLT5 is offline   Reply With Quote
Old 03-08-2006, 02:30 PM   #4
Shrek
CF Senior Member
Shrek's Avatar
Quote:
I asked for simple and I got simple! Isn't it strange how easy it is to over think something like this?
Wasn't sure if that could be done with the Haibeck chip. That will be the first thing I'll try.
Now, where did I put that damn power key?
THANKS!
Old 03-08-2006, 02:32 PM   #5
Zr1 Destroyer
CF Senior Member
Zr1 Destroyer's Avatar
Location: Thornton,Co. Press 1 to Proceed in English or 2 for Deportation ...don't let the fence hit you in the azz!
The only way I new for sure was by removing the plenum to see how they felt by hand . I removed them completely so I could sleep better at night and the car hits harder then ever!
When I removed them I pulled the shaft out that the secondaries bolt to and I was amazed by how rough and bound up the bearings that hold/pivot the secondaries felt compared to a brand new one that I had in my tool box! I'm sure that when the engine warms up they may move a little better........but if I left the secondaries in, I would have replaced the shaft/bearings with brand new ones to be 100% sure of the opening process.
Zr1 Destroyer is offline   Reply With Quote
Old 03-08-2006, 02:56 PM   #6
phrogs
CF Senior Member
phrogs's Avatar
Yeah but then you need that silly little tool to mess with the secondary shaft probably cost $500 from kent moore tools, Thats what the secondary plate tools cost insainity at its finest!
phrogs is offline   Reply With Quote
Old 03-08-2006, 03:08 PM   #7
Zr1 Destroyer
CF Senior Member
Quote:
This may sound a little barbaric...........after I removed the IH's I used a needle nose style set of vise grips with some gentle taps on the handle and they came right out and I plugged them with some small freeze plugs from autozone!
I'm sure they have some pricey tool to do that procedure with but it is not needed for this fun/little shadetree Zr1 customization.
Old 03-08-2006, 03:11 PM   #8
phrogs
CF Senior Member
phrogs's Avatar
Thats not barbaric ive done worse
but you should be able to rotate the secondaries in a complete circle and I havent been able to do that on a LT5 yet they all stop at some point.
Maybe some carb cleaner in there
Reload this Page Secondaries???
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
Anyone running no secondaries and closed loop? wdo-mkr C4 ZR-1 Discussion 30 08-31-2005 07:40 PM
Double Pumper or Vacuum Secondaries? matchframe C3 Tech/Performance 24 08-10-2005 03:19 PM
Secondaries not opening up…Why? Sartana C1 & C2 Corvettes 14 08-10-2005 01:04 PM
My thoughts on secondaries...... MrCrowley C4 ZR-1 Discussion 36 07-06-2005 06:22 PM
My 421cid LT5 IS ALIVE AND WELL!!!!! NITROUS JUNKIE C4 ZR-1 Discussion 196 04-10-2005 11:53 PM
Put on sidepipes, now secondaries seem way out of wack 73 LS-4 C3 Tech/Performance 10 02-22-2005 03:14 PM
Carb secondaries, Vac vs. Mech. bud snyder Engine Mods 12 09-30-2001 03:59 PM
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
