Corvette Forum
Go Back   Corvette Forum > C4 Corvettes, 1984 - 1996 > C4 ZR-1 Discussion
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
C4 ZR-1 Discussion General ZR-1 Corvette Discussion, LT5 Corvette Technical Info, Performance Upgrades, Suspension Setup for Street or Track
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 03-07-2006, 09:56 AM   #1
falconfling
CF Senior Member
falconfling's Avatar
Default Which bring up the question....
What is the best way to store parts ?
I'm getting a 2nd engine to play with, but for any parts, I would
think humidity and dust would be the only real enemies.
I mean, what does cast iron(edit cast iron/aluminum) care if its chilly or hot ?
My first thought is store the engine on a stand or pallet inside a plastic "bubble" with silicon drying packets to remove humidity.
For rotating parts, occasionally turn them over/regrease 'em.
Advice/options/opinions ????
Also...anyone ever see a LT5 in a C5 ? Why you ask....welllll
There is a really good kit car co. (is it factory five...can't remember offhand) that has a great looking rig that uses all C5 parts (except for a Porsche transaxle). OK I know....but if you're dreaming why not think of one with the beast in it.
Last edited by falconfling; 03-12-2006 at 11:17 PM. Reason: satisfy the purists amongst you
falconfling is offline   Reply With Quote
Old 03-07-2006, 11:39 AM   #2
TommyL
CF Senior Member
TommyL's Avatar
If your motor is complete, GM reccommends you "fill" it to the top with oil for long term storage. Other iron parts should be oiled or greased and sealed in plastic.
TommyL is offline   Reply With Quote
Old 03-07-2006, 12:05 PM   #3
cuisinartvette
CF Senior Member
St. Jude Donor '05
I keep both of mine inside on a stand....about 10 feet from my bed
The view is nice in the morning
cuisinartvette is offline   Reply With Quote
Old 03-07-2006, 12:11 PM   #4
Crabs
CF Senior Member
Crabs's Avatar
Falconling:
Twice in your posts you mention "Iron".
LT5's ain't got no 'stinkin iron.
's all 'luminum.
Get 'er straight, get 'er Dunn...
TomC
Crabs is offline   Reply With Quote
Old 03-07-2006, 01:51 PM   #5
wdo-mkr
CF Senior Member
wdo-mkr's Avatar
Quote:
Originally Posted by Crabs
Falconling:
's all 'luminum.
Of course there is all that forged steel to contend with too.
wdo-mkr is offline   Reply With Quote
Old 03-07-2006, 09:12 PM   #6
falconfling
CF Senior Member
Default Point taken
Falconling:
's all 'luminum.
TomC
but then again we still call Deetroit, motor city.
Old 03-07-2006, 11:04 PM   #7
zesstey1
CF Senior Member
zesstey1's Avatar
Ron to much info
zesstey1 is offline   Reply With Quote
Old 03-08-2006, 12:48 AM   #8
Rkreigh
CF Senior Member
Falconling:
's all 'luminum.
TomC
not quite true. the block has some iron in the main saddle bores which will indeed rust. chevy insisted on this even though Lotus argued it wasn't necessary. cams are chilled iron, rods are steel, bolts, ect.
filling the entire engine with oil isn't a bad idea, but most just lightly oil the liners and bag it. keeping it inside sure does help as does the dry bags to get rid of any moisture in the air.
keep in mind all the 94/95s had "old new" engines that sat around a long time after the production run in 93 when they last prod lt5s were built. they came out OK
Rkreigh is offline   Reply With Quote
Reload this Page Which bring up the question....
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
Question: What Chevy car went 0-60 in UNDER 4 seconds? DJ Dep C3 Tech/Performance 57 12-10-2003 10:43 AM
Killed the FP...that did not take too long.... ski_dwn_it C4 Tech/Performance 96 06-26-2003 09:08 AM
Horsepower question Robert N C3 Tech/Performance 10 07-13-2002 12:43 AM
I started up the Vette for the first time this year, and I've got a quick question... 92BAV C4 Tech/Performance 12 03-06-2002 03:11 PM
Dead at Age 10: the Big-Block from Hell Hib Halverson C3 Tech/Performance 46 12-07-2001 03:45 AM
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
