Corvette Forum
Go Back   Corvette Forum > C4 Corvettes, 1984 - 1996 > C4 ZR-1 Discussion
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
C4 ZR-1 Discussion General ZR-1 Corvette Discussion, LT5 Corvette Technical Info, Performance Upgrades, Suspension Setup for Street or Track
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 03-06-2006, 04:11 PM   #1
gunnerja
CF Senior Member
St. Jude Donor '09-'10-'11
gunnerja's Avatar
Default MSD Injectors?
Check out the link below and give me your recommendations. I have never used MSD before and am curious.
http://cgi.ebay.com/ebaymotors/MSD-2...QQcmdZViewItem
gunnerja is offline   Reply With Quote
Old 03-06-2006, 04:13 PM   #2
DDSLT5
CF Senior Member
DDSLT5's Avatar
They might be fine. I would stick to RC injectors if I was switching from stock - JMO.
DDSLT5 is offline   Reply With Quote
Old 03-06-2006, 07:39 PM   #3
Burnt71
CF Senior Member
Burnt71's Avatar
ttt
Burnt71 is offline   Reply With Quote
Old 03-06-2006, 11:14 PM   #4
Aurora40
CF Senior Member
Aurora40's Avatar
FWIW, they are $59 from Summit Racing, and with a $9 S/H charge for the whole order, vs $5 per injector. And they are a bit more well-known and you can return stuff.
But I believe they are exactly the same as the GM 1990-92 secondaries, just in a different package and a bit cheaper. If you just need new secondaries, want to keep the price low and/or want to stay stock, they seem like a nice buy.
I'd just toss out that you can get the '93-95 secondaries for not too much more, though. I got Delphi-branded ones for about $67 per injector. They look basically the same too, and are "updated" over the '90-92 style.
Aurora40 is offline   Reply With Quote
Old 03-07-2006, 12:51 AM   #5
gunnerja
CF Senior Member
gunnerja's Avatar
Quote:
Advantage for being updated?? Help me out here.
Old 03-07-2006, 02:15 AM   #6
Hooked on Vettes
CF Senior Member
As mentioned the MSD's should work fine. If you have a 90-92 they can only be used as replacements for the
Secondaries.
You can't use the MSD's for the Primary injectors because on the 90-92's the nose of the injector is machined differently.
Some one has mentioned you can use a rubber grommet in the injector housing to make them fit for the Primary injectors but the injector connector is also keyed so you'd need to address that problem.
The specs. for the MSD's are rated @ 43.5lbs of pressure and flow, 21lb/hr, or 220cc/min.
The reason the 90-92 Multec injectors fail is because the injector coils are cooled by the fuel. Some chemical additive in the fuel eats the injector coil insulation and the coil will short out.
Coil windings should measure around 12 ohms hot or cold. Factory specs. say anything from 10-14 ohms is ok.
It's also said that the Secondary injectors have problems if you don't exercise the Secondaries because the tip of the injector pits and causes a bad spray pattern or the injector leaks.
The RC injectors have a stainless steel body so supposedly you will never have the pitting problem.
I'm guessing the RC injectors are made by Lucas.
Hooked on Vettes is offline   Reply With Quote
Old 03-07-2006, 07:24 PM   #7
Aurora40
CF Senior Member
Aurora40's Avatar
Supposedly the '93+ style is more resistant to failure, etc. I don't really know, but they did change them, so you could go under the assumption newer is better?
But I don't believe any injectors intentionally have fuel flow over the coils?
Old 03-07-2006, 09:03 PM   #8
Hooked on Vettes
CF Senior Member
http://teamzr1.com/cgi-bin/ultimateb...1;t=000055;p=0
Reload this Page MSD Injectors?
Tags
injectors, msd, review
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
Secondary Injectors RatRacer C4 ZR-1 Discussion 19 08-06-2002 09:19 PM
FS: brand new 34# MSD injectors vette&fun C4 Parts for Sale/Wanted 13 05-24-2002 05:21 PM
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
