C4 ZR-1 Discussion General ZR-1 Corvette Discussion, LT5 Corvette Technical Info, Performance Upgrades, Suspension Setup for Street or Track
anyone have a spare throttle body laying around?
Old 01-03-2006, 10:23 PM
phrogs
phrogs's Avatar
Default anyone have a spare throttle body laying around?
Just like it says im looking for one.
I also have one that would be a good one for a larger what is it 63mm But I need a stock one.
finish isnt important so it can be stained and some corrosion is ok
thanks
I have alot of stuff for trade so let me know
johnny
Old 01-03-2006, 10:55 PM
cv67
cv67's Avatar
Received 3,043 Likes on 2,602 Posts
St. Jude Donor '05
What do you mean by the one you have is good for larger? Has it ben reworked?
Old 01-03-2006, 11:57 PM
phrogs
phrogs's Avatar
Little bit about that one.
I bought a motor a couple of years ago and this TB is from that motor, what had happend was the idiot who had it striped the screwes that hold the top plate on and when they tried to drill the screws out they drilled off center and all the way through the TB into the area that the plates are at.
I proceded to remove the bolt and I took it to a harley shop in town and had a friend of mine weld it up but it still needs to be machined perfect.
It has been rough machined back to its original size but still needs to be completed.
This one would be perfect for a larger TB due to its need to be machined already
I hope that makes sense I can snap some pictures if you want
jp
To anyone have a spare throttle body laying around?
Quick Reply: anyone have a spare throttle body laying around?
