Corvette Forum
Go Back   Corvette Forum > C4 Corvettes, 1984 - 1996 > C4 ZR-1 Discussion
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
C4 ZR-1 Discussion General ZR-1 Corvette Discussion, LT5 Corvette Technical Info, Performance Upgrades, Suspension Setup for Street or Track
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 12-21-2005, 06:22 PM   #1
WydGlydJim
CF Senior Member
WydGlydJim's Avatar
Default Planning on changing the oil........
for the first time over the Holidays. I know the '90 reqires 10-w30. I plan on using Amsoil 10w-30 synthetic. I guess the car should sit all night due to the inverted position of the filter. Any other things I should look out for. I don't have any manuals for the car yet. Should I get some before attempting any service? Which ones to get, and where? I found the jacking instructions on the registry. Is there way to get all the oil out in the process, or does some stay in the cooler? Looking for a little advice here.......don't want to do something stupid!
WydGlydJim is offline   Reply With Quote
Old 12-21-2005, 06:46 PM   #2
1990 QUASAR BLUE
CF Senior Member
1990 QUASAR BLUE's Avatar
I usually get it up on stands and then let it drain overnight. I know that's overkill but, it's the way I do it. The following morning I reinstall the drain plug, and it usually takes about nine quarts to refill. I believe that about three quarts always remain in the system. I don't think that there is any way to get it all out without pulling apart the cooler and all the lines.
1990 QUASAR BLUE is offline   Reply With Quote
Old 12-21-2005, 07:22 PM   #3
DRM500RUBYZR-1
CF Senior Member
DRM500RUBYZR-1's Avatar
the thread above is good advice; all i will add is when you begin adding oil,stop after about 7 qts, and begin checking the dipstick after allowing time for oil to settle down.
it is much easier to add a quart, then to try and remove it if you overfill.
and bad stuff can happen if overfilled!
if i have a shop do it, i have them do it the same way, and i only let them fill it with the 7, or until the low oil light goes out. i top it off at home after it sits for a few hours. again, much easier to add then to remove.
But, you should have no trouble, even the filter rarely gives probelms with letting loose it's contents, then again i wait a bit, and i use gm black filters.
go forward armed with your skill and common sense and you will be fine,
although you will find absoluetely GREAT TIPS from this site, when you do have a question. (didn't mean mine heh,heh.)
HAVE FUN PLAYING!, THEN HAVE REAL FUN, DRIVING!
DRM500RUBYZR-1 is offline   Reply With Quote
Old 12-21-2005, 08:30 PM   #4
Zproud
CF Senior Member
Zproud's Avatar
I drain for 2 hours and add 9 Qts of mobil 1... also did the coolant this time around 3 gallons out 3 in
Zproud is offline   Reply With Quote
Old 12-21-2005, 08:30 PM   #5
90 Corvette ZR-1
CF Senior Member
90 Corvette ZR-1's Avatar
Send a message via AIM to 90 Corvette ZR-1
I put it on ramps, let it drain for an hour, put the plug back in, refill and enjoy
90 Corvette ZR-1 is offline   Reply With Quote
Old 12-21-2005, 09:07 PM   #6
allvegashomes
Guest
Quote:
The fact that the oil filter is inverted does not matter. Just changed mine. Other than the GUSH of oil coming out of the oil pan (careful), no
other problems. Not a drop came out of the oil filter. Engine was warm.
Old 12-21-2005, 09:18 PM   #7
DRM500RUBYZR-1
CF Senior Member
Way to Go, VEGAS!!!
Playin with that Car after only 1 week
the affair goes to the next level!
You da MAN!
After the oil gushes out, 1-2 ceremonial beers should gush in...
AFTER the test drive of course
CONGRATS ON THECAR!
Old 12-21-2005, 09:36 PM   #8
Bigvmaxx
CF Senior Member
Bigvmaxx's Avatar
Jim If your anal like me... I suck the cooler down also... One 10 mm bolt on the passenger side between the oil lines. The top line ( both will be exposed ) is the one I run my clear plastic hose into. I slice the hose at a steep angle so it is pointed on the end... When I feed it in and meet resistance at the top before it turns downward I simply twist the hose and it goes around the corner as I push. When it gets to the bottom it will decidedly stop again. Attach the mighty vac and start a siphon into a can. All the oil should be out in an hour or 2. When I refill I can get 10 quarts in... or, about 30% more fresh oil than normal...
MAKE SURE YOU RE-ATTACH THE COOLER LINES CORRECTLY !
Hope that is anal enough for you !
Merry Xmas
Ted
91 ZR-1
Sun City, CA
Bigvmaxx is offline   Reply With Quote
Old 12-21-2005, 10:36 PM   #9
A1990
CF Senior Member
A1990's Avatar
Don't worry about the filter. It will be empty, I think gravity takes care of that! I think that if the car is cold, most, if not all of the engine oil, not counting the oil cooler, will be in the pan. If it is warm then the draining process might take a longer period of time as noted earlier. When you refill, it takes a while for the oil to make its way to the pan, so you should wait a period of time...before assuming that you have the right amount of oil in.
The surge as the oil comes out of the pan is somewhat surprising, but after that, some patience is the best measure.
Do some detailing while you are waiting!!!
A1990 is offline   Reply With Quote
Old 12-21-2005, 10:48 PM   #10
cuisinartvette
CF Senior Member
St. Jude Donor '05
Quote:
Originally Posted by DRM500RUBYZR-1
Way to Go, VEGAS!!!
You da MAN!
CONGRATS ON THECAR!
Wrench on that b!cth
cuisinartvette is online now   Reply With Quote
Old 12-21-2005, 11:36 PM   #11
emejay
CF Senior Member
emejay's Avatar
I have found to get the most oil out without removing the oil cooler, I lift car with floor jack, remove drain plug, lower car for several hours, lift car up again on one side at the greatest angle my jack will lift, leave at this angle for a couple hours, lower car ( watch how much more oil drains!), let sit for another couple hours, then lift the opposite side of the car to the greatest angle the jack will lift, leave a couple more hours, lower car again (note more oil drains!) and finally replace plug and fill with oil. I would not go to this much effort for any other car, but I love my 94 Admiral Blue!!!!!!
emejay is offline   Reply With Quote
Old 12-22-2005, 01:59 AM   #12
ZR-71
CF Senior Member
ZR-71's Avatar
Quote:
I kinda do the same except I use two floor jacks and only let it down once overnight. And as was said, it usually takes 9 quarts to get it back to full, just have to be patient in letting it trickle into the pan.
__________________
1991 ZR-1 Blk/Blk #2027
ZR-1 and SR-71: World Speed Record holders
ZR-71 is offline   Reply With Quote
Old 12-22-2005, 02:17 PM   #13
allvegashomes
Guest
Way to Go, VEGAS!!!
You da MAN!
CONGRATS ON THECAR!
Thanks my friend and cheers. The girl and I are just getting to know each other! Gonna change the rest of the fluids next week once I figure out where/how they come out! Also want to change the cam chain tensioner however do not know 1) where it is and 2) how to remove it! Any advise is GREATLY appreciated.
Happy Holidays!
Old 12-22-2005, 02:19 PM   #14
allvegashomes
Guest
I'm ready! Just don't know what I am looking at yet!
Old 12-22-2005, 02:26 PM   #15
DDSLT5
CF Senior Member
DDSLT5's Avatar
The filter should be full, and it shouldn't spill a drop if you're using the proper filter - i.e. K+N or Mobil 1.
DDSLT5 is offline   Reply With Quote
Reload this Page Planning on changing the oil........
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
How do you change the Differential oil? Drill and tap housing for drain plug? 2funnn C4 Tech/Performance 16 06-03-2011 06:03 PM
Technical Oil Filter Test vettenuts C5 Tech 23 04-04-2003 07:14 AM
Hib Halverson on Oil changes and filters Steve02C5 C5 Tech 10 03-04-2002 10:23 PM
Made the switch to Royal Purple Flintstone C5 Tech 18 01-21-2002 07:35 PM
Anyone else using 10w-60 synthetic oil in ZF 6spd? 2funnn C4 Tech/Performance 17 10-01-2001 07:18 PM
It's Official! 6.5 qts and not 7 qts of oil Mark S. C5 Z06 Discussion 23 09-03-2001 11:53 AM
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
