Corvette Forum
Go Back   Corvette Forum > C4 Corvettes, 1984 - 1996 > C4 ZR-1 Discussion
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
C4 ZR-1 Discussion General ZR-1 Corvette Discussion, LT5 Corvette Technical Info, Performance Upgrades, Suspension Setup for Street or Track
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 12-21-2005, 03:58 PM   #1
kick16
Junior Member
Default Sorry Guys, I Had To!!!!!!
Im Guilty...
I'm the guy that slid in the last few seconds on the "thrashed" ZR1 that ended on eBay a couple of days ago...
http://cgi.ebay.com/ebaymotors/ws/eB...RK%3AMEWA%3AIT
And im SYKED!!! I am planning to pick the car up either tonight or tomarrow and will certainly let everyone know how it goes. Hopefully it won't turn out like the fiasco I read about with allvegashomes's transaction through eBay....
Also, I've been reading quite a few threads recently on this ZR1 forum trying to learn as much as possible. Is there anything in particular I should look at when I go to pick up the car??
Thank You, and I look forward to hearing from you guys and learning as much as I can from this forum!!!
-Kyle
kick16 is offline   Reply With Quote
Old 12-21-2005, 04:07 PM   #2
phrogs
CF Senior Member
phrogs's Avatar
Theres nothing wrong with that car!
It apears they wanted alot more for the car is this a solid deal?
johnny
phrogs is offline   Reply With Quote
Old 12-21-2005, 04:16 PM   #3
TommyL
CF Senior Member
TommyL's Avatar
johnny
Looks like a little cleaning some TLC and you will have a nice ZR-1. Congratulations
TommyL is offline   Reply With Quote
Old 12-21-2005, 04:32 PM   #4
88BlackZ-51
CF Senior Member
88BlackZ-51's Avatar
Quote:
Originally Posted by kick16
Im Guilty...
-Kyle
how much was it lowered?
88BlackZ-51 is offline   Reply With Quote
Old 12-21-2005, 04:49 PM   #5
DDSLT5
CF Senior Member
DDSLT5's Avatar
Quote:
bout a inch!
DDSLT5 is offline   Reply With Quote
Old 12-21-2005, 08:37 PM   #6
Zproud
CF Senior Member
Zproud's Avatar
Congratulations
looks like a nice find!
Zproud is offline   Reply With Quote
Old 12-21-2005, 09:02 PM   #7
allvegashomes
Guest
Im Guilty...
-Kyle
You go buddy! At that mileage I would not expect any problems. Just learning myself. Not sure how you can go wrong at this price. I would be looking to see if everything lines up. Body damage is pretty easy to detect. Look for signs of a repaint around the door trim and any place the panels come together. My first clue was the removable top did not line up with the window. Upon closer examination I could see overspray and a difference in the smoothness of the body. Check the rubber seals - newer on one side than the other = accident. Look for any leaks ect. Make sure windows/lights go up and down with due speed. A rattle at startup indicates the cam chain tensioner may need to be replaced. Take the car for a spin and warm it up a little. When you stop check RPMS. If RPMs stay approx @ 1500 then drop you may have a vacuum leak. Check ALL gauges and idiot lights. See posts. Very helpful. Have phun!
Old 12-22-2005, 02:04 AM   #8
ZR-71
CF Senior Member
ZR-71's Avatar
I think you done pretty well. It seems, though it was run hard at times, it was maintained decently, at least that's what was claimed.
Let us know more as you drive it.
__________________
1991 ZR-1 Blk/Blk #2027
ZR-1 and SR-71: World Speed Record holders
ZR-71 is offline   Reply With Quote
Old 12-22-2005, 12:20 PM   #9
LoTu5
CF Senior Member
LoTu5's Avatar
Congratulations,you will love it
LoTu5 is offline   Reply With Quote
Old 12-22-2005, 12:23 PM   #10
Aurora40
CF Senior Member
Aurora40's Avatar
Quote:
I believe this was fixed with a new ECM program. If you had a vacuum leak, I don't think the rpms would drop, it would stay high idling.
Also, wrt the side window, the window can be adjusted. If it isn't meeting the top properly, it probably just needs to be adjusted. You have to take the door panel off to do this, but it's not too difficult.
Aurora40 is offline   Reply With Quote
Old 12-22-2005, 12:38 PM   #11
SledUtah
CF Senior Member
St. Jude Donor '06
SledUtah's Avatar
Congratulations on the ZR1, looks like a good deal. I've had mine a few months now and love it.
SledUtah is offline   Reply With Quote
Old 12-22-2005, 01:32 PM   #12
allvegashomes
Guest
Funny! I really don't know for sure why my car is idling this way. Been doing it since purchase. Read another thread and it seemed to indicate this as my problem???? You think ECM program????
Old 12-22-2005, 03:14 PM   #13
allvegashomes
Guest
Im Guilty...
-Kyle
Just saw your car online looks SWEET!
Old 12-22-2005, 03:52 PM   #14
Aurora40
CF Senior Member
Aurora40's Avatar
I'm hardly a troubleshooting expert. But I do think that if you had a vacuum leak, it would leak all the time, not just after coming to a stop. What I mean is, why would the idle drop down after a few seconds? Did the leak go away?
What seems a little more likely is that the ECM isn't dropping it quick enough when you stop. If you put the car in neutral while cruising, you'll see it holds a higher idle. I assume this is to ease the transition back into a gear at some point. If you put it in neutral while stopped, it idles lower, at the normal idle point. If yours takes time to drop, I'd guess it's related to the ECM rather than to a leak. But I'm just guessing.
There was a new program for 1990 and 1991 cars to resolve an issue like the one you describe. You can pull the PROM from the ECM very easily and check the program code stamped on it. It's at least a start towards figuring it out.
Old 12-22-2005, 03:54 PM   #15
EEegs
Junior Member
How do you get in ther and make that adjustment? Is there a link with pictures of this 'cause you are noe the third person to suggest doing this.
EEegs is offline   Reply With Quote
Old 12-22-2005, 03:56 PM   #16
We Gone
CF Senior Member
We Gone's Avatar
Congrats & enjoy
We Gone is offline   Reply With Quote
Old 12-22-2005, 04:05 PM   #17
Aurora40
CF Senior Member
Aurora40's Avatar
Quote:
It was 5 years ago easy that I did this to my 1987 'vette... Once you get the door panel off it should be fairly apparent. You'll see the rails the window rides on, and there are screws or bolts or something that you can use to adjust how angled in or out the glass is and such. I'm sorry I can't recall specifics, but it wasn't too hard to do when I did it. I had a Haynes manual at the time, though the proper Helm manual would be an even better choice.
Old 12-22-2005, 04:20 PM   #18
EEegs
Junior Member
Old 12-22-2005, 05:12 PM   #19
YorkL8apex
CF Senior Member
Support Corvetteforum!
YorkL8apex's Avatar
CONGRATS You got a heck of a car. I had a freind of mine that is involved in SCCA check on who may have owned it. I asked the seller if it was Duke Langley's car and he said it was.
It has all the stuff to contend at the national level in SCCA Solo II
I was with you up to about 15, you got a hell of a car there pal
YorkL8apex is offline   Reply With Quote
Old 12-22-2005, 05:19 PM   #20
YorkL8apex
CF Senior Member
YorkL8apex's Avatar
Reload this Page Sorry Guys, I Had To!!!!!!
Tags
corvette, duke, langley
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
Its snowin and I just had to take it out :-) JTS97Z28 C5 General 61 12-02-2004 05:48 PM
Sorry guys, but I feel I need to update you on Labelle now Patman77 C6 Corvette General Discussion 10 11-26-2004 08:31 AM
I hate to say this, but... VetteCrazy02 C5 Z06 Discussion 102 09-12-2003 12:53 AM
What can I do to lower my engine temp in stop & go traffic? Tigerhawk C4 Tech/Performance 36 05-25-2002 04:04 AM
Sorry guys, wife says I have to sell my C-4 !! rafzz4 C4 General Discussion 39 05-07-2002 11:47 AM
SORRY, but, I'm starting to dislike Corvette Fever now... rob75383 C3 Tech/Performance 36 12-28-2001 04:16 AM
Paging No Mercy, Your car isn`t really that nice looking.(Sorry) Am I Badd C5 Tech 24 12-16-2001 05:11 AM
Raleigh Dyno Day - Thanks, guys... I had a great time! GSDreamin' Southeast 22 11-07-2001 01:38 AM
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
