Corvette Forum
Go Back   Corvette Forum > C4 Corvettes, 1984 - 1996 > C4 ZR-1 Discussion
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
C4 ZR-1 Discussion General ZR-1 Corvette Discussion, LT5 Corvette Technical Info, Performance Upgrades, Suspension Setup for Street or Track
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 12-19-2005, 12:28 PM   #1
LoTu5
CF Senior Member
LoTu5's Avatar
Default Blose Amps.
Ive got a bad amp in the passenger side rear on my 91,it has been making a horrible noise and i narrowed it down to the amp,can these be fixed or are they a "throw away" item?
Thanx
LoTu5 is offline   Reply With Quote
Old 12-19-2005, 12:35 PM   #2
DRM500RUBYZR-1
CF Senior Member
DRM500RUBYZR-1's Avatar
Cannot offer any advice, but had to congratulate you on the
"Blose" Amps.
Not only very witty, but enirely TRUE on multiple levels!
Well- Done!
DRM500RUBYZR-1 is offline   Reply With Quote
Old 12-19-2005, 12:40 PM   #3
LoTu5
CF Senior Member
LoTu5's Avatar
Quote:
"Blose" Amps.
Well- Done!
I remember seeing it used on this forum and it made me chuckle at the time,bl**dy things.
Old 12-19-2005, 12:48 PM   #4
Demps
CF Senior Member
Demps's Avatar
ZR-1.net
Dr Don's is highly recommended. Bose Corp itself offers a lifetime warranty--I think.
Ted
Demps is offline   Reply With Quote
Old 12-19-2005, 12:59 PM   #5
DMark
CF Senior Member
DMark's Avatar
Cliff,
I would recommend that you replace all four amps at the same time. Once the first "BLOWS" amp goes out the others are quick to follow.
Another way to improve the sound is headers/no-cats/Flowmasters!
DMark
DMark is offline   Reply With Quote
Old 12-19-2005, 01:20 PM   #6
FU
NCM Lifetime # 982
St. Jude Donor '06-'07-'08-'09-'10-'11
Support Corvetteforum!
FU's Avatar
Location: Big government & Blue States stink. BABYLON NY
I agree with DMark ! Get them all done at Dr. Don's.
No high's no low's ? Must be Blose !
FU is offline   Reply With Quote
Old 12-19-2005, 01:56 PM   #7
JordiZR1
CF Senior Member
Cliff, the amps are easy to repair, I have fixed myself 7 out of 8 amps (4 in my car and 3 from a friend's ZR1)
All you have to do is replace the 6 capacitors that tend to fail (2 big black ones and 4 smaller green ones, if I remember correctly), unsoldering them from the board and soldering the replacement in the same place, you can get the capacitors and a small soldering iron from any electronics shop, 4-5 sterling pounds will get you the parts needed for all your amps.
There is a post somewhere in this same forum about how to do it, and maybe also in the ZR1net
Maybe it is another "demo" for the next get-together in the UK...
cheers mate!
JordiZR1 is offline   Reply With Quote
Old 12-20-2005, 07:04 AM   #8
jabrun
CF Senior Member
jabrun's Avatar
cheers mate!
I did the same thing. It just takes some time with a pencil soldering gun, I got my capacitors from Radio Shack. They were not exactly the same value as the originals but close. There is a number on them for the value. I used the post on the net as a how to guide and probably had less than $30 worth of parts. Go to ZR1.net site and type in bose amp repair in their search catagory and you will find how to do it.
jabrun is offline   Reply With Quote
Old 12-20-2005, 09:01 AM   #9
tomtom72
CF Senior Member
tomtom72's Avatar
Default Blose amps...
Hi Cliff, The net registry site does have the instructions for a do it yourself repair. I sent all mine to Bose, it was not cheap, over $300 with the shipping. They work fine & they replace everything including the speaker so all you get back is your mounting plate the rest is R & R'ed. They say that they have altered the amp circuitry a bit to get better sound. I can't speak to that as mine didn't work at all, nothing to compare it to.
The only thing is the system still has no bass, IMHO, my std radio in my DD tempo sounds better than my bose!?!?
& gingle bells!
Tom
Oh I forgot this, WEGONE replaced his rear speakers with C5(?) units I think?? Look over at the Zforum there is a thread on it. I know the thread was about getting more watts using stock vette rear speakers from a later model corvette.
tomtom72 is offline   Reply With Quote
Old 12-20-2005, 09:34 AM   #10
LoTu5
CF Senior Member
LoTu5's Avatar
Thanks for the advice Chaps,i will have a go at them myself first now ive got a reference and if i make a hash of them then its Dr Dons for some replacements.
Again the forum comes up trumps with helping me sort another little problem,much appreciated
Old 12-20-2005, 11:28 PM   #11
-=Jeff=-
CF Senior Member
-=Jeff=-'s Avatar
Wanna try to fix them yourself?
http://www.zr1netregistry.com/Bose2.pdf
pretty easy to replace the caps if you are good with a Soldering iron
I have done 7 so far, all still working well
__________________
-=Jeff=-
1990 ZR-1
NCM Lifetime member
My Website
Member: Fox Valley Corvette Club
1989 Custom Coupe (SOLD)
-=Jeff=- is online now   Reply With Quote
Old 12-21-2005, 12:11 AM   #12
zesstey1
CF Senior Member
zesstey1's Avatar
Cliff if you can find one get a solder remover its a round thing that suck solder off cheap and works great on circit boards.
zesstey1 is offline   Reply With Quote
Old 12-21-2005, 02:40 AM   #13
RICHARD TILL
CF Senior Member
RICHARD TILL's Avatar
you can do it. i fixed my left rear last nite. if you have an old one, theres usually some good parts left to rob off it. i replaced (robbed) 2 transistors off an old board and it worked. it had low distorted volume and was squealing loud. i had nothing to lose and the price of a new one to gain. good luck to you.
RICHARD TILL is offline   Reply With Quote
Old 12-21-2005, 11:38 AM   #14
LoTu5
CF Senior Member
LoTu5's Avatar
Thanks for the advice and encouragement,ile get onto it and let you know how i fare,thanks
Old 12-23-2005, 12:02 AM   #15
Cdn Z06 Mike
CF Senior Member
Cdn Z06 Mike's Avatar
Send a message via MSN to Cdn Z06 Mike
I remember reading that some of the old Nissan's used the same Bose amps and that they could be swaped. You may be able to pick some out of a wrecking yard perhaps real cheap and easy.
Cdn Z06 Mike is offline   Reply With Quote
Old 12-23-2005, 01:00 AM   #16
LoTu5
CF Senior Member
LoTu5's Avatar
Quote:
Thats a brilliant tip,i might make a trip down the Breakers later and investigate,ive just got the tools to do the job so i will have a go.
Seasonal wishes.
Reload this Page Blose Amps.
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
Replace Speakers and Radio and Amps Help dailo Audio/Electronics 9 03-28-2005 08:44 PM
Put 4 new amps in for my Bose, now no sound! Dixie91 C4 General Discussion 32 08-13-2003 10:37 AM
Bose amps to Dr. Don's Strick C4 General Discussion 21 08-05-2003 08:18 PM
BLOSE quit!! Stereo Install questions (and Alpine CDA-7894 info needed) Z06_BluByU C4 General Discussion 19 11-25-2002 10:17 AM
Stereo dork needs good advise from the pros on upgrading my 1989 Blose system. 89vette Audio/Electronics 26 05-17-2002 01:35 PM
Time to replace the Blose jaa1992 Audio/Electronics 17 03-10-2002 08:19 PM
Why did my Bose amps burn up? CELT4 Audio/Electronics 17 01-30-2002 07:06 PM
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
