Quote:
Originally Posted by zr11990broken
How much further does tha nose stick out than the stock nose ?
I just had knee surgery and can only get around on sticks or I would go measure both pieces for you. Stock nose is up in the attic & my mobility is too limited right now. If it's not too late, I could get the measurements for you in about 3 wks.
Quote:
Is the car still a bottom breather or does it breath through the grille opening?
Contrary to appearance, it is still a bottom breather for cooling, and the stock engine air intake is not affected by the LPE nose . I put the forced air intake on it to pick up air inside the grill opening, but only the lower half of the A/O intake opening is below the top of the grill opening. I am making a custom ram that will span the width of the grill and is about 1.75" high, funnelled back to the A/O inlet. It will sit back inside the grill a few inches and be painted flat black and be barely noticeable. On the dyno, the A/O forced air intake caused a loss of about 10 hp as compared to open throttle horn. I think the new ram air pickup I'm building will generate positive power gains @ 100+ mph, but no real good way to tell for sure. The Texas mile might be a good way to tell if you could get 2 runs, with & without the A/O forced air. Some of the Einstein types around here might be able to calculate the Hp difference (assuming the forced air went faster)
As it is out of the box, the nose opening (grill) is just for looks. The fiberglass C-beam that spans the frame rails prevents any air from entering the engine compartment through the opening. The lower ducts will work great for brake cooling when plumbed up.
Quote:
I am considering buying the nose, rockers and doors to put with a glass rear that I bought a long time ago but I am concearned with the length of the beak
If you're in a hurry for the info, I can try to get someone to help me measure. Let me know. What rear are you putting on?
Jerry
