I'm FINALLY putting the injectors, plenum, etc. back together after having the plenum & injector housings ported/polished.
Just realized that I should replace the injector o-rings (one of them is damaged) but I'm confused as to the number of o-rings. These are stock injectors.
1) there are 8 of the smaller o-rings where the injectors fit into the housing. Right?
2) are there larger o-rings that fit into a groove or channel? I have one of these o-rings on one injector and I'm assuming that I didn't notice that the others were stuck in the housing before I had the work done.
3) are there any other o-rings associated with the injectors?
Last question ...
Where are the o-rings available? Dealer? Kurt White?
I have access to an o-ring supplier locally. Does anyone know the correct sizes? Or should this be avoided?
Thanks in advance. I just know that someone on the forum will have the answer(s).
George
__________________ 1990 ZR-1 & 1997 LS1 Visit my site
The manual states to use new o rings every time you remove injectors, but I removed and reinstalled them mine 5 times without problems. Advisable if you remove them often, but not so much if you dont plan on removal until many years down the road.
I may have some extra o-rings for the injectors in my garage at home if you still need some.
Thanks for the offer ... located what I needed locally at AC Delco parts store.
Thanks also to all who responded .... you were a great help, especially the part about not having to replace the o-rings each time you have the fuel rail off. With the exception of one damaged o-ring, the rest look brand new.
