Corvette Forum
Go Back   Corvette Forum > C4 Corvettes, 1984 - 1996 > C4 ZR-1 Discussion
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
C4 ZR-1 Discussion General ZR-1 Corvette Discussion, LT5 Corvette Technical Info, Performance Upgrades, Suspension Setup for Street or Track
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 11-05-2005, 12:28 AM   #1
EEegs
Junior Member
Default Infl Rest Light
I have a 1990 ZR1 with 20K miles. I have owned for about 2 years and this warning light has been on since I bought it. I finally decided to do the "fix" I read about on the ZR1 Net. I decided to go one further and replace both sensors. All is now tight and hooked up properly. The car has no mods other than a Doug R chip and intake sensor relo. Light is still on. Any Ideas?
Mike
EEegs is offline   Reply With Quote
Old 11-05-2005, 12:41 AM   #2
DDSLT5
CF Senior Member
DDSLT5's Avatar
Quote:
Mike
The sensors rarely go bad, so that was a bit of a waste of money. Did you reset the code? If not, then you need to do that and see if the code comes back. There is a specific way to reset it - by grounding and ungrounding one of the pins in the aldl - can't remember offhand, but the thread on the net should tell you. The codes that come back after you reset will tell you which side is still not grounded properly.
DDSLT5 is offline   Reply With Quote
Old 11-05-2005, 01:16 AM   #3
Zr1 Destroyer
CF Senior Member
Zr1 Destroyer's Avatar
Location: Thornton,Co. Press 1 to Proceed in English or 2 for Deportation ...don't let the fence hit you in the azz!
Mike
I have a 90 air bag code clearance tool from Mid America. It's FREE if you want it, just send a few dollars for shipping. It worked for my 90 back in the day(before the destruction), PM me if ya want it!!!
Zr1 Destroyer is offline   Reply With Quote
Old 11-05-2005, 01:19 AM   #4
EEegs
Junior Member
Got it, I replaced because I read that it could have been the sensors so I figured, I'm in there, why not...I did not reset the code. That's good advice! I will do that. Thanks
Old 11-05-2005, 01:47 AM   #5
DDSLT5
CF Senior Member
DDSLT5's Avatar
You're welcome - Ry's offer for the code clearer is a sweet one - it is difficult to do it without this tool as the timing is essential. I would take him up on it if I was in your shoes! Good luck.
Old 11-05-2005, 06:05 AM   #6
boatman
CF Senior Member
boatman's Avatar
I bought Gordon's plugs for around $30 or $35. Then for insurance, I bought the Mid-America gadget for around $29, all plus shipping.
Then a few of the forum members walked me thru it, and with a piece of wire from my work bench. To clear the codes, I had to have a longer piece of wire to ground it to the seat frame.
Cost of the pieces of wire? $0.00.
Not knocking the other high-tech gadgets I bought, but the pieces of wire worked for me.
Eeggs: How did you get the passenger side sensor out, or how did you get to the mounting bolts?
Boatman
boatman is offline   Reply With Quote
Old 11-05-2005, 08:44 AM   #7
Yibbutkeen
CF Senior Member
Yibbutkeen's Avatar
The diagnostic module in mine went bad. After finding a replacement, I examined the old one. There are 2 covers on the unit - 1 over the connector and a 2nd with a warning about 35v.
Under the 2nd cover is a removeable capacitor module. My cap had shorted, causing the module to fail.
Good luck
Yibbutkeen is offline   Reply With Quote
Old 11-05-2005, 08:47 AM   #8
tomtom72
CF Senior Member
Support Corvetteforum!
tomtom72's Avatar
I'm with Boatman on that Q! I looked at the pass side sensor & it looks like the inner wheel well panels, center & rear, must come out & the fender comes off and the washer bottle has to be removed.
Any one else see the same things?
Tom
tomtom72 is offline   Reply With Quote
Old 11-05-2005, 09:36 AM   #9
EEegs
Junior Member
On the pass side sensor, it actually was very easy. 1) Rear wheel well piece comes out. 2) take out the forward bolt first. 3) rear bolt is almost impossible to reach but you can loosen it with some finess. 4)Once you get it to break you can spin the sensor around for easy access. I found that to be much easier then taking out some of the other parts. I will warn you that it is not the easiest place to reach but doable!
Old 11-05-2005, 09:43 AM   #10
tomtom72
CF Senior Member
tomtom72's Avatar
Thanks Mike for the insight!!
Tom
Old 11-05-2005, 09:53 AM   #11
Tyler Townsley
CF Senior Member
Another thing to check is the connections under the dash. It is a different looking connector that will get some oxidation and cause the same problem. Use some contact cleaner on it and reconnect.
Tyler
Tyler Townsley is offline   Reply With Quote
Old 11-05-2005, 11:11 AM   #12
EEegs
Junior Member
The diag. module is not one I have heard or read about...anyone else?
Mike
Old 11-05-2005, 11:59 AM   #13
boatman
CF Senior Member
boatman's Avatar
Default Under Dash Connection
[quote=Tyler Townsley]Another thing to check is the conunder the dash.nections It is a different looking connector that will get some oxidation and cause the same problem. Use some contact cleaner on it and reconnect.
After cleaning up the drivers side sensor, the passenger side sensor looked fine, (I hoped as it looked new).
One of the forum members, and now I forget his name, from New Jersey, called and walked me thru the testing and clear codes process. JeffVette, Tyler and TomTom gave me good advice on this also.
I looked up under the dash, passenger side, and right behind the top of the carpet was the connector. Looked fine, and I think they are gold plated. I dis-connected, sprayed electronic cleaner on the pins, etc., hooked back up, connected battery, then was able to clear the codes successfully.
Boatman
Old 11-05-2005, 05:47 PM   #14
EEegs
Junior Member
Default Got It
Ok thanks to all here!! I have cracked the INFL Rest problem. Check out this article. As you can see above I replaced both sensors but I was still getting 16 & 15 code (see article, I'm an expert now ) I followed "ED's" method to reset but I did have to try it several times.
http://www.corvetteforum.com/techtip...D=46&TopicID=2
Old 11-05-2005, 06:10 PM   #15
DDSLT5
CF Senior Member
DDSLT5's Avatar
Here comes the bitchy part - if the light stays off for a week, you've got it licked. If it comes back on...........troubleshoot again! Good luck.
Old 11-05-2005, 08:04 PM   #16
EEegs
Junior Member
I know...I am trying to be positive
Old 11-15-2005, 12:48 AM   #17
EEegs
Junior Member
It has been a week and still no problems. EEegs 1, INFL 0
Old 11-15-2005, 12:54 AM   #18
DDSLT5
CF Senior Member
DDSLT5's Avatar
Sounds like you're good to go! Congrats - they can be a bugger sometimes - yours should be good for life now!
Old 11-15-2005, 07:09 PM   #19
Cdn Z06 Mike
CF Senior Member
Cdn Z06 Mike's Avatar
Send a message via MSN to Cdn Z06 Mike
Ok not to highjack this thread (sorry) but what is the ramifications of not fixing this problem. Mine has been on for the past year also!
Cdn Z06 Mike is offline   Reply With Quote
Old 11-15-2005, 09:23 PM   #20
Tyler Townsley
CF Senior Member
The air bag on that side will not deploy in an accident. Check the connector first, it is easy to get to and seems to be the real problem in most cases.
Tyler
Reload this Page Infl Rest Light
Tags
c4, infl, light, rest, zr1
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
INFL REST light Sliding C4 Tech/Performance 9 08-13-2002 08:30 PM
INFL REST LIGHT mfemma C4 Tech/Performance 9 04-30-2002 06:50 PM
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
