Low RPM stumble/miss
Cruise-In III Veteran
Cruise-In IV Veteran
Cruise-In VI Veteran
St. Jude Donor '03-'05-'06-'10-'11-'12
Help me out here, it seems my beast has developed an attitude at low RPM's.
It seems to happen under the following conditions:
Key on or off,
Temps normal
RPM less than 1500RPM
Throttle position >25%
No Codes set.
As soon as it gets over 2K, it pulls to the stratosphere, all the way to 7000+.
I was trying to think if it did it at all before I installed the headers, but I can't say for sure. I don't think it did, but I can't swear to it.
Is false knock a possibility? I haven't scanned it yet but it seems that even last year when I had the stock manifolds on it, I had some knock counts. I run 93 all of the time.
Ok, hit me up with the ideas!
Key on or off,
Temps normal
No Codes set.
Originally Posted by Jeffvette
Check plugs for fouling
Check plug wires to make sure they are seated
Originally Posted by ShawnZR-1
I checked the wires last night, I'll check the plugs this weekend when the car has a chance to cool enough. FWIW, the plugs and wires were the first things I thought of.
Did you use an ohm meter to check the wires? I had one that was inconsistent, the motor still ran reasonably fine, and the wire itself looked perfect, but the connection was frayed at some point - if the wires are original, time to replace them.
I replaced the wires around October last year, they're not the originals. I only checked to make sure they were seated. I didn't go under the plenum to check them end to end yet. I have a feeling it's a mucked up plug, but I haven't had a chance to pull them. The car doesn't cool down enough at night and in the morning, well, I do have to go to work. I'll yank them out this weekend and see.
Update: #2 plug was fouled as all get out. Black and carboned up. Runs like a purring kitten now! God, I love simple fixes!
